Intake Manifold issue
Old Jun 19, 2008 | 03:44 AM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Hello,
We are doing a 350 swap on my car however the 350 came from a carb'd car. I am going to be sticking with the TBI setup as I am more familliar with tuning a TBI than messing with a carb.
The problem is. The intake manifold off of my 305 TBI will not bolt to the 350 block. The intake manifold for the 305 has angled bolts that bolt to the heads where the 350's manifold mounts are right into the block. Is there something I can do to rectify this? Looking for a cheap solution. Let me know
Old Jun 19, 2008 | 04:47 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Intake Manifold issue
Oval the holes on the manifold.
Old Jun 19, 2008 | 07:21 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yep.
Old Jun 19, 2008 | 07:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes it will. It just doesn't line up to the heads.
Like said, elongate the intake bolt holes. The center two on each side.
Old Jun 19, 2008 | 07:40 PM
mouthforcombat's Avatar
Car: '86 Iroc Z
Keep it carb'd man... Pop a four barrel on there and it beats a TBI setup any day. It's probably more simple than TBI, too, especially since it's already on the motor.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
