comp cam roller rocker question
Old Jun 24, 2008 | 12:32 AM
GMZombie's Avatar
Car: 89 Camaro RS Convertible
Engine: 355 chevy power
Transmission: 5 speed manual
Axle/Gears: standard
just a quick question i have a set of roller rocker arms that are 1.52. my question is i have a 72 350 bored .30 over with i believe are 327 heads in my camaro right now. will these arms work or will they be to short as i also see there is a 1.60 size...so confused.i have a .488 lift comp cam so i believe my stock rockers arms will not be good enough for that.
Old Jun 24, 2008 | 12:44 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: comp cam roller rocker question
1.52 rockers are a good replacement . no problem if you use them to replace stock rockers . 1.6 rockers open valves a bit ( a little bit ) more . remember H.S. geometry that you slept through . good luck .
Old Jun 24, 2008 | 02:44 PM
GMZombie's Avatar
i never got specific math classes just all integrated into one couse where the teacher didnt know **** lol...
Old Jun 26, 2008 | 03:23 PM
GMZombie's Avatar
my dad keps telling me that those rockers wnt work. h says they were on a 350 that had a circle track cam in it which was way to radical but he says that the pushrds kept rubbing up against the heads. d you believe that it was cause of the cam or maybe I need some longer rckers?
Old Jun 26, 2008 | 03:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It'll depend on whether they're self-aligning rockers or not, and which heads you have.
Old Jun 26, 2008 | 11:32 PM
GMZombie's Avatar
i have stock 327 heads that were redone cause they sat for a while and umm is there an indication on the rocker arm on what kind it is other than the 1.52?
Old Jun 26, 2008 | 11:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You can tell self-aligning rockers from non self-aligning ones by looking at the tips. Self-aligning rockers will have "ears" on them that go on either side of the valvestem.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
