Valve Cover Bolt Woes
Old Jun 26, 2008 | 06:18 PM
87GTAj's Avatar
Car: 87 Trans Am GTA
Engine: 5.7L TPI
Well I've been trying to trace my oil leak for awhile now, and I thought I had found the problem. Then, it turned into a bigger problem. The oil is hitting the header on the passenger side and running down to the exhaust piping, then blowing around at will. I went to check and see if the valve cover bolts on the pasenger side were snug, and the one closest to the firewall was loose - very loose. In fact, it came right out and this is what it looked like:
Beside it is a full bolt. What I want to know is, will I be able to get it out, how bad is it to remove the passenger side valve cover (with lines running everywhere)? Will I need to try and use a bolt extractor or will there be enough bolt in there to remove it with hand tools? I can't really start on this til Sunday at the earliest and I've got an appointment on Wednesday to have the new tires put on. Any help is appreciated, as always. Thanks.
Old Jun 26, 2008 | 06:58 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Re: Valve Cover Bolt Woes
can't see the picture so it is hard to answer.
Old Jun 26, 2008 | 11:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Ah, genuine chinesium bolts. . .
You may be able to get to it, may have to drill it out.
Old Jun 27, 2008 | 07:13 AM
Big Dave's Avatar
Car: 1992 RS Heritage
Transmission: TCI 700r4
IF there's any of the bolt sticking out of the boss, you can try getting a pair of vice grips on it and working it loose. More likely, you'll need to drill it out.
Getting the passenger valve cover off is no fun with all the stuff in the way. Good luck!
Dave
Old Jun 27, 2008 | 07:44 AM
AsphaltAssalter's Avatar
Car: 92 Camaro
It depends on how the "screw" was installed, if it broke because it was bottomed out in the casting then it could be a bugger to get out, if it just broke from fatigue then you may be able to twist it out by had if you can get a grip on it.
Old Jun 27, 2008 | 11:51 PM
87GTAj's Avatar
Engine: 5.7L TPI
Thanks for the info guys...I'll let you know how it goes.
NBrehm
Aug 25, 2015 11:49 PM
1985chevydude
Aug 20, 2015 12:29 AM
blackd-out z28
Aug 15, 2015 08:18 PM
mustangman65_79
Aug 8, 2015 01:18 AM
