Choppy Idle
Old Jun 29, 2008 | 12:48 AM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
Choppy Idle
I got a 87 trans am 5.7 tpi 350 and it idles high then it idles low sounds like someone is givin the car throttle idk what the problem could be ,anyone know?
Old Jun 29, 2008 | 07:36 PM
rezinn's Avatar
Re: Choppy Idle
Could be a number of things. You could start out by cleaning the throttle body and idle air control valve, checking for vacuum leaks. This article might be helpful for adjusting your idle: https://www.thirdgen.org/tpimod2
You could also check out the tpi board and search for similar problems people have had.
Old Jun 29, 2008 | 10:13 PM
87transGTA's Avatar
Car: 87 GTA
Re: Choppy Idle
tpi board what is that?? sorry im kinda a noob
Old Jun 29, 2008 | 11:23 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Choppy Idle
You are on the 'Tech/General Engine' board right here... theres a section if you go back one more page thats dedicated just to the TPI engines.
I would start looking for vacuum leaks, as an unusually high idle and a rough idle are typical symptoms of that.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
