Vortec 5700 L31 installed in a 3rd gen??
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
I ran across a very low mileage (20K) Vortec longblock from a 99 GMC truck for pretty cheap. I've thought about putting Vortec heads and the Vortec TPI intake on my 91 GTA 350 L98 block. My question is what issues would I have to deal with installing the Vortec longblock in my car with the TPI intake?
Thx. in advance for any help.
Transmission: 4L80E/4L80E
The only issue would be the Vortec TPI base. You should be good to go.
Why not just install the longblock? You could swap over your L98 cam if you like, or get something aftermarket.
Car: 91 Formula
Re: Vortec 5700 L31 installed in a 3rd gen??
I was doing a little research and there might be a water pump reverse flow issue if I want to use a 88-92 Serpentine setup.
The serpentine water pump is reverse rotation. Neither L98 nor Vortec are reverse flow.
Car: 91 Formula
Will the 88-92(f-body) Serpentine setup and water pump work on the Vortec 5700 L31?
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
You should remove all the truck accessories anyway and bolt all your f-body stuff to it. I doubt the truck stuff will even fit in the car. I dont know about the reverse flow or not waterpump issue, but if you just throw the water pump off hte L98 on there with the rest of the serpentine system you wont have any problems. They may well be the same, though. SOme water pumps have the pulley lined up in a different spot (Farther out in front the motor or closer to the motor) and so if you're going to move the serpentine system over, jsut get a water pump to match - problem solved.
Car: 91 Formula
Summit calls out a reverse flow WP for a 88-92 5.0 and 5.7 in Camaros and Firebirds. 96-2000 5700 Vortec 5.7 call for a standard flow WP.
Here is the problem I see: You cannot use a standard rotation WP with a 88-92 Serpentine setup because to get all the other acc. to work they must turn the right direction and to do that you would be turning a standard WP the wrong direction.
The 88-92 Serpentine bolts right up to a Vortec engine.
What would happen if you installed a reverse flow WP on a engine that did not come from GM with a reverse flow WP?
Car: 91 Formula
Most GM Serpentine setups will not work in 3rd gen F-bodies because of hood clearance issues, especially truck setups.
Car: 1986 IROC
Engine: 355" TPI
The only reverse flow engines are the LT1 type. Reverse rotation is different and for use with serpentine setups. You should have no problem using whats on your camaro right now.
Take everything you read on summitracing.com with a grain of salt. Love 'em to death, but they get a lot of things wrong.
As stated, LT1 was the only, ever reverse "flow" engine. The water pump also happened to be driven by the cam.
Serpentine car and truck systems use a water pump that rotates in the opposite direction as the engine, and are therefore called reverse "rotation" water pumps - the flow direction is the same as always.
L98 (after '88), L31, LB9 (after '88), LO3, LO5, all those engines with serpentine systems, were standard flow (block first) and reverse rotation water pumps.
Car: 91 Formula
So the coolant runs thru the engine the same(besides the LT1 type)its just the acc. belt turning the WP pulley the opposite direction when they state reverse rotation-flow WP?
Car: 91 Formula
Ok, I just checked Autozone and Advance and they are stating the same thing as Summit did. 88-92 Camaros and Firebirds use a reverse rotation WP and 96-2000 Vortec V8 use a standard rotation WP.
Is this because of the different Acc.-Serp setups on 88-92 Camaros and Firebirds compared to a 96-2000 truck setups?
Car: 91 Formula
I have a 99 GMC K1500 Z71(old body style)with the L31. I'm going to check this issue I have out tomorrow.
Thx. for all the input.
Car: 1992 Camaro RS
That's all it is. If you use a 88-92 thirdgen water pump, you wont have any problems. It's not reverse flow so much as it is reverse rotation because of the way the belt is set up. The water flows in the same direction on all Gen I blocks. The pumps are different because of different belt systems.
Car: 91 Formula
five7kid, I totally agree with you about summitracing.com. I have found so many errors especially when it comes to years applicable and got errors-bad advice from the employees at the store-warehouse here in Atlanta.
It took me awhile but I'm finally getting it. I guess I have burnt to many brain cells in my life with that wacky weed. LOL
Car: 91 Formula
Another question:
Can I use the L98 TPI cam in my 91 engine and install it the L31 without changing the lifter and pushrods? Are the lifters and pushrods the same in the L98 and the L31?
Yes, you can use the L98 cam in the L31 engine. See Post #2. Lifters and pushrods are the same.
Car: 91 Formula
Looks like I'm gong to buy the engine since it seems I won't have any issues.
Do these roller cams and lifters wear out? I have heard they last a longtime with very little wear.
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
the stock l31 cam is better i think
Car: 91 Formula
I got the specs on the stock 90-92 L98 cam but not for the L31 cam.
Car: 91 Formula
GM Stock Cams
Model Number .05" Duration 1.5:1 Lift 1.6:1 Lift Lobe Sep. Notes
14093643 202/207 .404/.415 .431/.443 114.5 87 350,305man
10088155 179/194 .350/.384 .373/.410 109deg 87 305 auto
10066049 207/213 .415/.430 .443/.459 117deg 88-89 350,305
10111773 202/207 .413/.428 .441/.457 114.5 90-92 350,305
I'm weak on cam specs but it looks like the 90-92 to be a better cam. This cam chart is from TGO. https://www.thirdgen.org/mods3
well u know the stock cam works well in the l31. question is are u going to use tpi on it still?
Car: 91 Formula
The L31 is just a longblock No intake. I'm going to use a Edelbrock or Dickey Vortec TPI base with all the other SD TPI parts.
Car: 91 Formula
If I install the L98 cam I believe I won't have to do as much prom re-programming.
Vortec heads flow like crazy compared to L98 heads
SD setups are rather particular on mods
You will need a tune for the longblock swap
Why not pick a decent cam while you're at it?
Car: 91 Formula
I'm not looking to increase HP and Torque too much over stock. I want to stick with a roller cam and lifters. Roller cams are $300 plus
I'm not looking to build a straight line car also.
Car: 91 Formula
Car: 87 GTA
L31 cam specs are not THAT far off the 92 TPI specs, but theheads themselves flow WAY better...plus the seqential firing order of the inectors equals better mpg. If you use the L31 ECM, distributor & wiring.
96 L31 Camshaft Profile
Intake: .275 X 1.5 = .412
Exhaust: .281 X 1.5 = .423
Lobe Separation 111 Degrees
Car: 91 Formula
Are the cam specs the same in L31 in trucks from 96-2000?
Car: 91 Formula
This engine is also coming out of a 2500 so it should be a 4-bolt main. From the research I've done.
Car: 87 GTA
As for cam specs over the years, I don't know the specific specs through the years, but I would suspect there was some improvement through the years.
Are you going to use the Vortec distributor or the TPI one?
Car: 91 Formula
Also a decent roller cam is $300 plus and since the Vortec TPI intake is so hard to find used, a new one is just shy of $500 shipped.
Car: 91 Formula
Probably the TPI distributor. Why?
Car: 91 Formula
I've only been able to find specs on the 96 L31 cam
I do know from my 99 GMC with the L31 that the distributors don't last, head and intake gaskets leak. These are common problems with the L31
Car: 87 GTA
The Vortec dizzy has the CPS (cam position sensor) in it for sequential firing of the Vortec injectors. IMHO a better, looking at least, cap which will not fit a standard dizzy.
As for the wiring differences, as in...can the TPI harness simply plug into a Vortec dizzy, I dunno. If so, the injector harness plug would simply be left emtpy. There would have to be a plug from the Vortec dizzy to the ECM to tell it which injector to fire when, then the ECM would have another harness piece to the injectors themselves.
Make sense? In my head I can see it all, but I'm not sure I'm explaining it right. Am I? Hope so.
Car: 91 Formula
Once the TPI is altogether and the plenum extension is on you can't really see the distributor.
Doesn't the Cam PS work with the Crank PS or is that just in the ECM? I had a code in my truck that was P1345 = Crankshaft position sensor / Camshaft position sensor correlation. It should say your crappy GM distributor is wasted.
I'm going to stick with the TPI distributor and make life easier.
Car: 91 Formula
I'm big fan of TPI intakes and not carbs.
This one has 906 heads.
According to Mortec the 062 were on 98.
12558062...98......350..........L31 Vortec, truck, 64cc chambers, 1.94/1.5, 170cc intake port
10239906...96-up...350.........."Vortec 5700", "L31", 64cc chamber,
170cc intake port, 1.94"/1.5" valves
What is the difference between the 062 and the 906? They look the same to me
Car: 91 Formula
Mortec info on the block:
10243880...350...95-00...2 or 4...Vortec truck, Gen.I crate motors and "ZZ4", roller cam, one piece rear seal
They have 95-00 but I believe it should be 96-00
well i am to but not when its not stock anyway. i just think its alot of trouble
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Car: 91 Formula
With roller, new isn't really an issue. You can get an LT1 or ZZ4 take-out cam for $150 or less.
Car: 91 Formula
Car: 91 Formula
I found this cam on Ebay: P/N 10185071
DESCRIPTION: CAMSHAFT Hydraulic Roller Tappet This hydraulic roller tappet is used on the 5.7-liter H.O. 350 ZZ3 & 4 engines. The duration at lash point in degrees (intake/exhaust) is 275/280; duration at .050" tappet lift (intake/exhaust) is 208/221; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 474/501. Valve lash is zero/zero and lobe centerline is 112 degrees.
Car: 87 GTA
That, I have no idea. But, I'd suspect the ECM looks at both & adjusts timing, based on if both are reading as synced, then throws a code/adjusts the timing as needed, to try to keep them together.
Car: 87 GTA
And with a carb, there goes anything resembling gas mileage. Something to consider with todays gas prices.
Besides, you can make more power AND get better mileage with EFI.
Yep.
.490 is the max you wanna run on a stock Vortec head. But it's fairly easy (for a machine shop) to up the lift capability.
Yep.
.490 is the max you wanna run on a stock Vortec head. But it's fairly easy (for a machine shop) to up the lift capability. Last edited by Stephen; Jul 4, 2008 at 10:01 PM. Reason: Automerged Doublepost
