Running like a pile of poo when warm.
Old Jul 5, 2008 | 09:57 AM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
I've been having this issue for a while when ever the car warms up a bit it starts to have a real bad hesitation if you step on it hard, it will even die if you don't let off the gas quick enough. Its also getting real bad gas mileage..... and at this point with gas prices the car is basically parked. Id love to get it back on the road again! any one got any suggestions?
oops BTW its a 1988 GTA with the 350 TPI
Old Jul 5, 2008 | 10:06 AM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Re: Running like a pile of poo when warm.
CTS (coolant temp sensor) will cause that problem. Does it run find when cold? After its warm and you shut it off, does it restart easily?
It could be the MAF sensor also but, replace the CTS 1st because they are cheap and the MAF sensor is not.
Old Jul 5, 2008 | 10:14 AM
Dokken10's Avatar
Car: 91 Formula
The CTS is located on the front(vertical) of the intake next to the fan switch and below the coolant fitting that the hose goes to the TB.
Old Jul 5, 2008 | 10:20 AM
Engine: 350 tpi
i actually just replaced the MAF because it was throwing a code, but the problem continued after i did. I have replaced cts when i first bought the car, im wondering if its the cheap carquest part that went bad already.
the car easily starts up every single time even after it dies. when its cold it runs great, just when it warms up it has a real bad hesitation when i step on the gas hard.
Old Jul 5, 2008 | 10:29 AM
Dokken10's Avatar
Car: 91 Formula
I would try another CTS and go from there.
Old Jul 5, 2008 | 11:57 AM
Engine: 350 tpi
well i replaced it and it seems a bit better, i still have a slight hesitation, but the car did sit for a long time and could have some dirty injectors or bad gas, im going to drive it around for a few days and see how the mileage is.
Old Jul 5, 2008 | 12:33 PM
Dokken10's Avatar
Car: 91 Formula
Run some injector cleaner thru it also. I had a 91 Formula that sat for awhile and could not get it to start without starter fluid(for a second or 2) long story short(hours of trouble shooting and reading manuals), I tapped all the injectors and then she fired right up.
Old Jul 6, 2008 | 04:36 PM
Engine: 350 tpi
well it ran pretty good yesterday but when i started it today and let it idle for a bit it idled at about 1k and would not drop into low idle. Should i reset the computer because i put in a new cts?
Old Jul 6, 2008 | 04:51 PM
Dokken10's Avatar
Car: 91 Formula
You could try that.
It could be the TPS is not adjusted right or going bad.
Old Jul 6, 2008 | 05:07 PM
Dokken10's Avatar
Car: 91 Formula
Could also be the IAC motor or a timing issue.
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
Street Lethal
Aug 14, 2015 08:25 PM
mustangman65_79
Aug 8, 2015 12:07 PM
