I have 2 problems
Old Jul 6, 2008 | 04:13 PM
panzer's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: limited slip
I have 2 problems
ok my first problem, sometimes when I try to start the car it just clicks but after a couple trys it turns over and starts. Starter core? My second problem, when I feel the need for speed I floor it then when I let off it the engine light goes on.
Old Jul 6, 2008 | 04:23 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: I have 2 problems
I don't know about the second but your first problem is the same one I have been having. I am chalking it up to heat soak but the other day when I was under there I noticed that one of the starter wires wasn't attached properly. It seems that perhaps sometime in the past the wire broke and whoever fixed it (wasn't me), stripped it back and crimped a new terminal lug on it...only problem is they only got half the wire. So I re-did the connection. Since I am swapping motors, I haven't seen if this is a good fix or not but I highly recommend that you check both your battery cables for good connections and pull your starter wires from the starter and inspect those. If they all appear to be in good order, then I suggest maybe replacing your solenoid and/or starter. IF that still doesn't fix it...then you got a doozy of a problem...and so do I! lol
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
