1991 L98
Old Jul 7, 2008 | 07:32 AM
marcus88's Avatar
Car: 87 GTA
Transmission: Automatics
1991 L98
Will I run into any problems using the long block from a 1991 L98 (Camaro) and using my 1989 intake?
Old Jul 7, 2008 | 08:28 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: 1991 L98
no
but what are you talking about
specifically
Old Jul 7, 2008 | 08:31 AM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Re: 1991 L98
marcus88 is thinking of buying my 91 L98 350 TPI longblock and installing it in his 89 Camaro that has a LB9 305 TPI in it.
We know about the knock sensor, Memcal, injectors etc. need to be changed to upgrade to the 350.
The basic question is:
Due to the slight difference in stock 88-89 TPI cams compared to the stock 90-92 TPI cams, will the 89 350 ECM/Memcal work without having it programmed?
Old Jul 7, 2008 | 08:43 AM
Dokken10's Avatar
Car: 91 Formula
Re: 1991 L98
Cam specs if this helps
GM Stock Cams
Model Number .05" Duration 1.5:1 Lift 1.6:1 Lift Lobe Sep. Notes
14093643 202/207 .404/.415 .431/.443 114.5 87 350,305man
10088155 179/194 .350/.384 .373/.410 109deg 87 305 auto
10066049 207/213 .415/.430 .443/.459 117deg 88-89 350,305
10111773 202/207 .413/.428 .441/.457 114.5 90-92 350,305
This cam chart is from TGO. https://www.thirdgen.org/mods3
Old Jul 7, 2008 | 08:55 AM
jamon8's Avatar
Engine: 350 tpi
Re: 1991 L98
I posted a thread about a guy who programs chip
he is good and he is cheap
I like him
http://www.scotthansen.net/index.html
Old Jul 7, 2008 | 09:01 AM
Dokken10's Avatar
Car: 91 Formula
Re: 1991 L98
I like him
Thats not what we are asking
but thanks for the referrence.
Old Jul 7, 2008 | 09:33 AM
jamon8's Avatar
Engine: 350 tpi
Re: 1991 L98
you need to have the memcal programed
Old Jul 7, 2008 | 09:39 AM
Dokken10's Avatar
Car: 91 Formula
Re: 1991 L98
If he uses the 89 305 TPI memcal or
If he uses a 89 350 TPI memcal?
I know the 90-92 Speed density Memcals are picky about changes but I thought the 85-89 MAF Memcals were not as picky about changes especially such a slight difference in cams like mentioned above.
Old Jul 7, 2008 | 09:43 AM
jamon8's Avatar
Engine: 350 tpi
Re: 1991 L98
the 305 maf memcal is a little diff than the 350 maf memcal
I could be wrong
vader and sofa have been known to rain on my ignorance
I am far from right all the time
human you may call it
Old Jul 7, 2008 | 09:49 AM
Dokken10's Avatar
Car: 91 Formula
Re: 1991 L98
I could be wrong
Sounds like your knowledge about this issue is the same as mine.
We need an expert to chim in.
All 305 memcals are different than 350 memcals.
Old Jul 8, 2008 | 09:01 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 1991 L98
The difference in camshafts is so small it will not make a difference to the computer.
Linson
Oct 24, 2025 02:00 PM
FormulasOnly
Jul 23, 2018 08:47 AM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
