enyone know what this ratting noise could be?(video)
Car: 1992 Camaro RS
Engine: 305 TBI
Re: enyone know what this ratting noise could be?(video)
have you checked heat shields ? sounds like a rattle more than a engine noise allso you said only when it warms up deff sound slike something heating up exspanding and rattleing
Car: 1992 Camaro RS
Engine: 305 TBI
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
i had a similar noise after i installed my serpentine setup, it was the bolt behind the p.s. pullie. it backed its self out and was rubbing and rattling on the back of the pullie.
Car: 1992 Camaro RS
Engine: 305 TBI
ya i was thought the noise could have been comin from the serpentine setup ill have to check all that
Car: 1992 Camaro RS
Engine: 305 TBI
Car: '91 RS Camaro
Engine: 5.0 TBI
Transmission: Manual
Axle/Gears: 3.08
Ive heard alt pullies make that noise. Enigine runs too good for it to be anything internal.
Very clean engine. Nice
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by cameron7710
when my camaro is warmed up it starts to make this noise enyone have a idea what it could be?
Car: 1992 Camaro RS
Engine: 305 TBI
good idea i sould have done that today when i changed the belt but ill try that tomorrow and if its the a/c thats just another reson for me to tear that thing out of there
Last edited by cameron7710; Jul 10, 2008 at 10:59 PM. Reason: Automerged Doublepost
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
And something that just came to mind. You say it happens after warm up... Maybe its the A.I.R. or water pump. Deff try removing the belt.
Car: 1992 Camaro RS
Engine: 305 TBI
Still could be. And it may sound horrid but doesnt mean its bad. My grandfather was seconds from giving me his truck because everyone thought he threw a rod (even me). Turned out it was a 12 dollar pully.
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Btw; what do you do/use to keep/make your engine so damn clean.
Good luck!
Car: 1992 Camaro RS
Engine: 305 TBI
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Take a long metal tool, like a prybar, breaker bar, or something similar, and listen to the different accessories. This should help narrow down where it's coming from. You do it by putting one end of the tool against your ear, and the other against the accessory. Be careful of the belt and pulleys, though. It's a handy trick my dad showed me, you can listen to pretty much any part of the engine - hold to the valve covers to hear the rockers, to the intake to hear the injectors, etc.
Car: 1992 Camaro RS
Engine: 305 TBI
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I had a similar rattle and just like mentioned above, there was a bolt that fell between the water pump pulley and the belt, so every time the pulley would turn, it would toss around the bolt and make that horrible rattle. I agree in taking off the belt. If that gets rid of the rattle, then spin the accessories by hand and see if you can see where its coming from... good luck!
Car: 1992 Camaro RS
Engine: 305 TBI
Car: 1992 Camaro RS
Engine: 305 TBI
ok so i just checked out the car and ward i took your advise with the pry bar thing which is really cool and every thing sounded fine.Then i took the belt off and it still made the noise so i started to lisen under the car and it sounds like its coming from the front underneth of the car so i think jay was right about the heat sheild. now i just need to figure out how to fix it.
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
had that same problem with my 88 ta. It ended up being the bearings inside the water pump. Also take your belt off and check you ideler pulley. the bearing may be shot inside that cause that noise. But now my engine makes that noise every once n awhile again n i found out its my p.s pump.
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Not sure if it's been said already but take the belt off and start the engine for just a few moments. Still make the noise?
Ditto on the long rod to your ear. Between these two methods you should be able to narrow it down quickly.
Car: 1992 Camaro RS
Engine: 305 TBI
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
288K! ESH My 127K must be considerd poo!Take a long metal tool, like a prybar, breaker bar, or something similar, and listen to the different accessories. This should help narrow down where it's coming from. You do it by putting one end of the tool against your ear, and the other against the accessory. Be careful of the belt and pulleys, though. It's a handy trick my dad showed me, you can listen to pretty much any part of the engine - hold to the valve covers to hear the rockers, to the intake to hear the injectors, etc.
I would vote heat shield or possibly where the exhaust bolts up to the manifolds (adaptors). Heat could cause them to expand and rattle if they are loose.
Car: 1992 Camaro RS
Engine: 305 TBI
288K! ESH My 127K must be considerd poo!Never knew of this. Good to know for future problems. Thanks.
Did you try the prybar trick on the valve covers?
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
lopped off the round bit at the end and put a rod in it's place. Doc Lawson we called him hehe! Best teacher I ever had, even when he kept calling the firebird a firechicken hehe! Senior Member
Car: 1987 Trans Am
well, its good and bad news its not the accessories. Good that its not an expensive accessory to replace. Bad that its not an accessory to replace. Does the rattle increase with rpms? I'd say jiggle around the exhaust components when the car is cold. Could be a bolt that came loose from the manifold and wye pipe flange and is just dangling loose. Jiggle the exhaust heat shields. Maybe its your car telling you that it wants headers! It runs too smooth for it to be internal...*crosses fingers*
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Belt tensioner - 99% guaranteed - not the pulley, but the tensioner itself. They are fairly cheap and easy to change though.
Car: 1992 Camaro RS
Engine: 305 TBI
well i took the belt off and it still made the noise so i dont see how it could be that
Last edited by cameron7710; Jul 12, 2008 at 02:11 AM. Reason: Automerged Doublepost
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
MY CAR MAKES THE SAME NOISE!!!!!
Its been driving me nuts for a while now. I cant locate it for the life of me. I have the smog and AC deleted and it still does it, I've run it without the belt besides. I fear it is in internal. You see, mine is not constant. Under engine acceleration (reving up) there is no rattle, but when I allow it to fall back to idle it rattles for several seconds (sometimes worse than others) then quiets down. Heres the kicker, if my engine is aprox. 1/2 quart low on the dipstick. Then it rattles constantly, until I refill it to near overfull levels. Then it goes back to the few seconds at idle.
I would PAY to find the cure for this!!!
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
May be bearing clearance. Hows your oil pressure? If its lowers a bit after idling try some thicker oil...
How we doing? Check anything yet?
Car: 91 Formula
Axle/Gears: 10 Bolt 3.23
Sounds very familiar, a while back I had almost that same rattle, it was exhaust. I have dual cats and there was a little bracket that kept the cats together and in place. Drove me nuts because I couldn't get to it well, at least not when hot without burning myself. Just happened to poke it with a screw driver one day and behold it went quiet. Ended up just sticking the business end of the mig welder in and pulling the trigger a few seconds blindly, been gone since. I would look at the not so obvious spots to see if something is hiding, lol missing any wrenches?
Car: 91RS, 91RS
Well, I have a completely custom exhaust; no rattles there.
Haha, no I'm not missing any tools that I know of.
Yeah my oil pressure is not so good at idle when hot. Its only about 25 psi. I've done some experimenting with oil thickness but considering I'm allready running 10w-40 with a bit of Lucas added I dont think any thicker is advisable. Hopefully she holds on till I can find the suitable parts for my engine swap.
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
pull 1 spark plug wire off at a time, if the noise stops its a bearing ( says small prayer before starting)hope this isnt what it is but it will eliminate the possibility, later jimmy
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Done this with 3 Jeeps, which they are common for bearing clearance issues. Did a full SeaFoam treatment and then used thicker oil; shut em right up.
Car: 1992 Camaro RS
Engine: 305 TBI
Car: 1987 Trans Am
something that will also greatly assist and making things like this a whole lot easier is making some wooden ramps so you can just drive up and go under instead of jacking your car up which is very time consuming. Just stack a few 2x4s and nail them together...
Car: 1992 Camaro RS
Engine: 305 TBI
ya i think i might have some ramps somwhere in my shed ima take a look a bit later
Good thing I only said 99% then, eh? My LT1 and a friend's TPI 305 both made that same sound (if I'm hearing the right one in the vid) and both needed tensioners to fix it.
sjorgens
Oct 1, 2015 07:54 PM
