deleting A.I.R.
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
deleting A.I.R.
I was thinking about deleting AIR and some other emissions systems from my car.
I had a few questions.
1.) Will this decrease gas mileage
2.) Will this put the computer "out of tune"
3.) Will this give me any more horsepower?
Thanks!
Bill
Thanks!
Bill
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Re: deleting A.I.R.
Well man i took everything off my car. About hp not much if any. Then my computer works fine nothing happend. Then you might increase mpgs but not lose any.
kevin
kevin
Car: 89 Firebird Formula
Engine: 305 Vortec, Single-plane, 4 barrel
Transmission: T5, soon 700R4
Axle/Gears: 88 10 Bolt, Disc, Auburn, 3.23
Re: deleting A.I.R.
Well, at the very least, you will be uncluttering the engine bay. I have a "cage" over my spark plugs from AIR and that's why I'll pull mine.
But, also removing 1 item from the belt drive is a good start aswell, though I doubt the pump uses much power.
Anyone know what type of fittings and sealing compound (if needed) would be used to plug the ports in the manifold?
I suppose I could measure them..
-Dave
-Dave
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: deleting A.I.R.
There are several threads on this topic in this Tech/General board, and the Exhaust board, both about how illegal it is in the United States, and how there is no gain except in cleaning up the engine bay.
Car: 1992 Firebird
Transmission: 700R4 with B&M shift kit
Axle/Gears: 3.23 zexel 4th gen
Re: deleting A.I.R.
I heard it will make your engine run slightly lean, but won't affect wot. Personally, my hatred for hippies was enough alone to convince me to remove mine.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: deleting A.I.R.
Well i took everything off from the cat to the air lines and you could slightly tell that it was breathing better or something.
kevin
kevin
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Re: deleting A.I.R.
"Placebo effect" ... lol.
A lot of people make horsepower in their minds. Stickers can do it for some guys.
Anyway, I am all for uncluttering the engine bay, but I'm not for bad air. I just did a full drivetrain and exhaust swap (355 TPI, rebuilt trans., rear end gears, hooker from front to back w/ catco converter) and left all of my smog equipment on. Even bought the headers with the A.I.R. tubes. So while my car is FAR from stock now, other than lots of shiny polished aluminum and chrome it still looks stock and will blow cleaner exhaust w/o really compromising power.
Car: 87 GTA
Re: deleting A.I.R.
A good engie (even a stock tune) doesn't need the AIR pump system, if thecat is good.
My system is gone, but I have a Magnaflow cat. And my emissions #s are virtually zero. So, despite my car being "technically" illegal, my #s are great.
Everything was gone when I bought the car, so I expected to have problems, but no.
Re: deleting A.I.R.
What other systems can be deleted (i.e. the Charcoal cansiter) and what is involved?
Also, when deleting A.I.R., will I need a new belt and a new pulley? If so, what size? Where can I buy them?
Thanks again!
Bill
Thanks again!
Bill
Re: deleting A.I.R.
The charcoal system is what cleans up the gas fumes from your fuel tank. Without it, you'll be smelling gasoline in your car. I would leave it.
The AIR system is there to clean up the emissions while the engine is cold and the cat-converter is cold. Without it, your cat-converter will fail sooner, unless you have a cat designed to work without air. Its all a moot point though, because it doesnt matter how clean the engine is without it, its still illegal on a street car in the United States to remove it. The technology has gotten better in the last 20 years, so if you want an engine without it, you can swap in an LS1 or LS2 or LS3.
