Vacuum hose routing
Car: 89 GTA
Engine: 5.7
Vacuum hose routing
Finishing off top end reassemble on 86 5.7 GTA TPI. EGR Solenoid has a connector for a vacuum line to clip in. I can't figure out where that hose comes from (not finding anything obvious). The solenoid has the hoses for the EGR valve the throttle body. Where does the missing hose rout from?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Vacuum hose routing
One goes from the solenoid to the bottom of the throttle body, as you said. The other goes from the solenoid to the EGR valve.
Car: 89 GTA
Engine: 5.7
OK- thanks. I've got that. There appears to be a 3rd connection on the "back" of the solenoid, next to the electrical connector. I'm assuming this is vacuum-in. Wondering where it routs from.
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
thats a vent, there should be a foam cube held in by the metal clips.
Car: 88GTA
Engine: 5.7TPI
I have a 88 GTA 5.7 similar question.....which port on the solenoid goes to the EGR valve. the bottom port or top?
Car: 1987 Trans Am GTA
Engine: 5.0 TPI
Car: 1991 Camaro Z28
Engine: L98 350
Transmission: 700-r4
Axle/Gears: 3.23 posi disc brakes
Blow in both of the hoses. To the egr solenoid with the car off. One hose you blow into will go out the "vent" (a small port with sponge like element on the end). That is the one that connects to the egr valve. The other port you blow into won't go anywhere. That hose goes to the throttle body. Hope this helps.
Car: 88GTA
Engine: 5.7TPI
Pac J
May 17, 2020 10:44 AM
HoosierinWA
Oct 7, 2015 10:15 AM
