CODE 33 on 89 Formula 305
Old Jul 14, 2008 | 12:21 AM
theMAGICALheat's Avatar
Car: 96 Souped up Firebird, 89 KITT
I was driving the car as normal, hit a light and wham! The car stalls and the CE Soon light comes right up, the car becomes hard to start, etc. I have the code diag'd. 33 MAF circuit high. SO I replace the MAF, BAM! Same code. I am now going to replace the Power relay, as I have no idea what else could cause this to keep giving a 33 after resetting the computer. Any help is greatly appreciated. Thanks!
Old Jul 14, 2008 | 12:56 AM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
Re: CODE 33 on 89 Formula 305
I get that code if i dont let the car warm up enough in the morning. she runs like a bag of *** and doesnt shift properly. pulll over, turn power off, turn car on, shes good to go again.
i havnt done much to fix the issue mainly because mines got a few electrical issues. and it doesnt happen all the time.
at http://www.troublecodes.net/GM/ it shows 33 relating to MAP related issues. and one MAF issue.
let me know what u find.
Old Jul 14, 2008 | 01:29 AM
Destructimus's Avatar
Car: 1992 Firebird
Transmission: 700R4 with B&M shift kit
Axle/Gears: 3.23 zexel 4th gen
Check your vacuum lines by looking at them for cracks, checking where they hook up, and listen for hissing if you don't have a tester. A bad vacuum seal could stall you out just like that.
Old Jul 14, 2008 | 11:25 AM
Thanks, going to replace the relay today and then do the TB POsition, vacuum check, and minimum idle if that doesn't work...already bit the big one by replacing the ^&(^(*(&( MAF.
Old Jul 28, 2008 | 02:15 AM
For anyone keeping score, it was the ECM as diag'ed by following the flow chart. Then BAM a 36 comes, and I go change the MAF burn off, all seems well now....thanks
gta90
Sep 15, 2015 04:00 PM
GouldyGTR
Aug 21, 2015 10:43 PM
Randomtask2
Aug 13, 2015 01:57 AM
