First car, suggestions/help?
Car: Camaro IROC-Z
Axle/Gears: 2.73's
Hey everyone, about 3 days ago I purchased an 88' IROC for $6,000. It is in mint condition and it has a 305 and hooker headers and a nice exhaust set up by lou's custom exhaust. Now, I am looking for some big performance upgrades because the performance factor just isnt there. If you need any additional info, just ask and I will post. Thanks. Oh yea, heres some pics, I didn't take them though, previous owner did.
http://www.cardomain.com/ride/2569097
Transmission: 4L80E/4L80E
Gears.
Cam.
Stealth Ram.
Higher stall converter.
350.
Cam.
Stealth Ram.
350.
Car: 1987 camaro RS/Z28 clone
Engine: 305 bored .030 over
Transmission: 700r4 slippin its way home
Axle/Gears: 9 bolt 3.43 gear
Re: First car, suggestions/help?
im not sure if its carbd 305 or tbi or tpi????
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
The car looks nice, you seem to want some power to back up that look, so definitely go with the 350 upgrade. Also, if you can swing it, go with an LS1 setup. That might actually give you some MPG savings as well.
Assuming you can keep the gas petal off the floor long enough to get a savings.
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
id start over with a 350, no offense to anyone but you can build more power with them in the long run
Car: 1992 Firebird
Transmission: 700R4 with B&M shift kit
Axle/Gears: 3.23 zexel 4th gen
If you don't want to get a 350 right away, a few good bolt ons you could do that will fit a 350 as well as a 305 are:
K&N filter/ cold air intake
MSD Blaster Coil
MSD Digital 6 or 6AL
Better Spark Plug and wires (8.5mm or bigger)
If it's tpi and you want to stick with that setup, you could get an adjustable fuel pressure regulator for it too.
You could always get a shif kit for the transmission too. I've heard some people have gotten good results out a sonnax tv cable corrector spring too, for firmer shifts. Those things are like $5 so you might as well try it.
Other than that, the other guys are right on. It just depends on what you want to do/have time for/have money for.
MSD Blaster Coil
Car: Camaro IROC-Z
Axle/Gears: 2.73's
Ok, I just found out that it is a tbi 305, now with hooker headers, edelbrock air cleaner how much hp do you think im running, and what are some suggestions as in like 350 price fully installed or just go with a lot of bolt on performance?
id turn it into a carburated engine first...
go with an intake manifold, a carburator, aftermarket hei distributor, and a cam...
all that stuff i just mentioned you can drop in a 350 later on.. see what you get out of the 305 . if you are not happy just transfer the parts from your 305 to your new 350.
Linson
Aug 21, 2015 02:12 PM
