Harmonic Balancers
Car: 89 irocz
Axle/Gears: 373
Harmonic Balancers
whats a pirtty good street balancer that will be able to handle 6,500 rpms?
what do you want a internaly balanced or externaly? whats the difference?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Harmonic Balancers
You want an internally balanced one if your engine is internally balanced, and an externally balanced one if your engine is externally balanced. Getting the wrong one is a Bad Thing. A stock type balancer should be fine for the occasional excursion up to 6,500.
Car: 1988 Trans Am GTA
Engine: 350 4BBL
External balance is for a stroker (400 crank) engine like 383 or 400.
Measure the outside diameter, if it's 6 3/4" get one like THIS.
Or if you have more money than brains, get one like THIS.
This would probably be a pretty good one..
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Both my 305 and 355 have balancers behind the crank pulley.
Engine: 383 Carb
Transmission: 4L60
All small block chevys have a balancer. The presence of the balancer has nothing do to with whether the engine is internally or externally balanced.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i got a romac balancer for my 383. its smaller than stock diameter balancers and its good to over 6500 so far. i've been to 6800 on the limiter and no problems so far
Fits well with factory 2 oclock pointers. You can get them on ebay for 250 bucks
Car: 89 irocz
Axle/Gears: 373
my motor is just a 350 that is new. the motor is has never been balanced so i dont know weather to use a exernal or internal balacer? sence its not a stroker should i go with internal??
Car: 89 irocz
Axle/Gears: 373
Car: 89 Iroc-z
Transmission: TH400
fluidampr is good. if the motor hasnt been balanced, then i'm not sure what i'd do there. all internals should be roughly balanced else you'll have vibrations inside and hurt your rpm range. Also wears harder on the bearings if not balanced properly
without knowing what is inside of that motor its hard to say what balancer is necessary. some rotating assemblies are external balanced setup some are internal, but i dont think you can mix them up.
Engine: 350 4BBL
Engine: 350 4BBL
. Thread Starter
Car: 89 irocz
Axle/Gears: 373
think i might go with this seems to be pritty resonable priced what do yall think? http://www.jegs.com/p/ATI/763411/10002/-1/10179
Engine: 350 4BBL
Those are available in 6" and 7". and the 7" won't fit...
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
geez, you just WANT to spend big money?
Go to summit, and grab their $59 one. It's got all the timing marks, and works great.
Engine: 350 4BBL
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
