heads 081 vs 083
Old Jul 19, 2008 | 08:42 AM
310IROCZ's Avatar
heads 081 vs 083
Need some sugestions. I am rebuilding a l98, has new rings bearings cam 232/234 with 488 lift, shorty headers edelbrock rpm and holley 600cfm also using stock l98 pistons. question is i have a set of both 081 and 083 heads both ported and polished stock valve size, what would you guys use? I have steel shim head gaskets i want to use as well as a 150 shot of NOS. it will be a once or twice a week driver.
Old Jul 19, 2008 | 07:39 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: heads 081 vs 083
1.94 valves?
Old Jul 19, 2008 | 11:49 PM
310IROCZ's Avatar
the 083 350 heads are 1.94 with a 64cc and the 081 305's are 184s and 58cc.
Old Jul 20, 2008 | 05:06 AM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
083 heads flow better and wont kill your wallet. 081 heads will raise compression way too high for the street.
I also wouldn't be worried about 1.94 valves..... they are capable of over 400 hp in a 350 if it's built right. The 1.84 doesn't flow enough though.
Old Jul 20, 2008 | 06:12 AM
310IROCZ's Avatar
Thanks, that was the way i was leaning as well, hope to make the 400#
Old Jul 22, 2008 | 02:22 PM
doc221978's Avatar
Car: '81 Z-28
350 short block
10.24:1 comp
vortec heads
xr 282 hr cam
holley 750
426 hp at the flywheel
Old Jul 22, 2008 | 04:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
uhh thanks for that doc, but it doesn't really have much to do with anything in this thread now does it?
310 IROC - which cam do you have? I fear it is a piece of junk, but i'd like to be sure. Part number?
Also, why a holley 600cfm carb?
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
