Car won't start
Old Jul 19, 2008 | 12:13 PM
dahn's Avatar
Car: 86 camaro
Transmission: 700 auto
Axle/Gears: 308
Car won't start
86 camaro 305 auto turn the key click,take out the battery carge it good clean connection.Car starts turn it off a couple times starts check the battery 12.85 volts.Disconnect the neg cable overnite,try to start it in the morning click,check the battery 12.65volts did'nt lose that much overnite.Disconnect neg cable and positive cable connect them back up car starts.Is this my starter or selenoid telling me their going out?The cables are clean.thanks
Old Jul 19, 2008 | 07:38 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: Car won't start
purple wire on starter or seliniod
Old Jul 21, 2008 | 05:47 PM
dahn's Avatar
Car: 86 camaro
Axle/Gears: 308
Re: Car won't start
Does that mean it's lose or broken so the seliniod is still good and it's just the wire?Thanks Don
Old Jul 21, 2008 | 07:49 PM
jamon8's Avatar
Engine: 350 tpi
Re: Car won't start
it means put a test light on the s terminal of the starter and have someone turn the key
test light lights= bad seliniod
Old Jul 23, 2008 | 04:50 PM
dahn's Avatar
Car: 86 camaro
Axle/Gears: 308
Re: Car won't start
Yep, it looks like it's bad.thanks
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
