How to install diff gears. What needs replacing?
Old Jul 20, 2008 | 10:14 AM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
I want to put a set of posi 10 bolt 3.73s that i have into my 1986 LG4 Iroc-Z 5spd. Can i do it myself or do i need to have a shop do it. Everytime i see differentials put it they use all these fancy meters to measure distances and stuff. How hard is it to install gears. And what should be replaced along with the gears/carrier and fluid? My car only has 45,000 miles on it. Thanks.
Old Jul 20, 2008 | 10:48 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: How to install diff gears. What needs replacing?
They need to be setup properly. Have a shop do it.
Old Jul 20, 2008 | 12:36 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
ok. Do i need to replace anything else.
Old Jul 20, 2008 | 02:24 PM
jv9999's Avatar
Engine: 5.7L/350
Usually you'll want an "install kit" that includes new bearings, seals, and shims.
Old Jul 20, 2008 | 02:54 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
ok. Do you know if any thing changed for 10 bolts over the years that would keep mine from installing?
Old Jul 20, 2008 | 04:18 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Nope. Should be straight forward. Just have a shop do it. Lots of little things that require special tools (like a pinion depth gauge for instance) and, if its not set up properly it will whine like crazy or might even grenade. Leave it to the pros.
Old Jul 20, 2008 | 05:03 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
It's not THAT bad... here are some good article on line that show you what's involved. See if it's something you can handle... It's a tedious job so a shop will charge you an arm and a leg to do it, so if you can make the investment in time and tools to do it yourself, then you'll be ahead of the game.
http://www.pirate4x4.com/articles/te...sta/Gear_Setup
http://www.drivetrain.com/ringpinioninstal.html
Old Jul 20, 2008 | 05:51 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
I dropped my car off tuesday and wont get it back till most likely wensday so you will be with out a car for a day or two. I am having other stuff done to though. But if you dont replace the speed gear and sencor then your speedometer will be off like 30 mph. (correct me if im wrong)
kevin
Old Jul 20, 2008 | 08:25 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
i saw them do it on spikes powerblock and it looked tedious. I'm gonna have a shop do it. How much do you think they will charge, and do they need to take the whole rear down?
Old Jul 20, 2008 | 09:35 PM
gcgarner's Avatar
GoodlookinRS is 100% correct about the speedo gears. You can search this board for "speedo gears" and probably come up with the right combination for you. The gears are dirt cheap, the problem is installing them.
And no ... they don't have to pull the whole rear. Just pull the cover off of the diff, pull the axles and voila!
Old Jun 21, 2012 | 05:39 PM
mat's Avatar
mat
did your trans is a mechanical speedo or electronic???1990 camaro i had a 2.73 to a 3.42 and now my speedo is way off there is no gear in the transmison is ther somting i can do to bring me speedo back to normal speed
Old Jun 21, 2012 | 08:01 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Here's a few things to consider when upgrading a 10 bolt. This is what I did with mine. A Eaton 28 spline posi, new 28 spline axles ,3.42 ring and pinion and LPW Ultimate cover. Here's a link to the Eaton posi unit. = http://www.eaton.com/EatonCom/Produc...iteId=EatonCom and here's a link for the LPW cover.= http://www.jegs.com/i/L.P.W./619/301-7.5G/10002/-1
This is what it cost me. $700.00 for master bearing kit , axle bearing and seals, 28 spline axles, including 3.42 ring and pinion, and labor .$535.00 for Eaton 28 spline Posi.,$169.00 for LPW Ultimate support cover.. 3 year warranty on parts and labor. Total = $1,404.00.
I will tell you that the new upgraded unit has made a "huge" improvement over the 2.73s and open rear.Drives like a totally different car.
Old Jun 21, 2012 | 08:16 PM
mat's Avatar
mat
ok ya i just baught a
PART # 542046 - AUBURN PRO SERIES DIFFERENTIAL 10 BOLT 7.5 (3.23-UP)-- 28 SPLINE
and all run a all stars 3.42 gear but now my speedo is all **** up since i hade a 2.73 orig. in the cars
what i can do to fix my milage on the cars do i need to change or reprograme a new ACM??
Old Jun 21, 2012 | 08:34 PM
mat's Avatar
mat
how did you fix your speedometer or you just dint bather with it?
Old Jun 21, 2012 | 10:44 PM
Engine: TBI,5.0
I did not need to change my speedo gears because I went over to 27in. tall 255/60r15 rear tires. The fix was really not intentional. Just happen to be right on the money, at least that's what those digital roadside speed limit boxes say.No problem with the cops radar guns either.( they like to shine one on my car every once and awhile.)
Most of the guys here replace the speedometer gears in the transmission. Some one else will have explained the process or do a search.
Old Jun 24, 2012 | 10:01 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Need to buy the correct speedo gear. A small plastic gear that installs in the side of the transmission. U need one for 342.
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
draco
Oct 4, 2015 09:25 PM
hectre13
Aug 26, 2015 08:17 AM
drathaar907
Aug 6, 2015 04:20 PM
