losing Idle
Old Jul 22, 2008 | 10:56 PM
19formula30589's Avatar
Car: 89 Formula
losing Idle
So i've been having an on going problem that i cant figure out. Its a 89 tpi 305. After i drive for about 20-30 mins when i get the stop lights the idle starts to drop not misfire just idle lower and lower each time i stop till it will just die out. If i restart it right away it will idle low for a few seconds and die, but if i turn the key back and shut everything off and restart it, It will run fine for another 20 mins. I have no idea what to even look for, im hoping someone has had this prob before
Old Jul 23, 2008 | 07:17 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Re: losing Idle
I would check ignition timing and also make sure that there is no coking on the throttle body, clean it with some throttle body/carb cleaner. What are the condition of your spark plugs, what is your fuel pressure? Check the normal stuff and get back to us.
Old Jul 23, 2008 | 08:15 PM
Car: 89 Formula
Re: losing Idle
timing is fine, tb is clean, plugs newer and fuel pressure is at 50 but never got a chance to check while it was happening. I think its something electrical because when i power everything down its fine for awhile
Old Jul 24, 2008 | 03:57 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: losing Idle
You might want to check your TPS (throttle position sensor) voltage at idle. The details are in the FAQs. Also, the IAC if the TPS looks good. Those two components control your idle.
Old Jul 24, 2008 | 09:16 PM
Car: 89 Formula
Re: losing Idle
I checked both numerous times
86IROC112
Nov 27, 2015 09:54 AM
IROCtometal
Sep 20, 2015 11:08 PM
Stryker412
Sep 20, 2015 06:59 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
