Are pushrods supposed to rotate?
Old Jul 25, 2008 | 05:03 PM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
I just took the valve covers off and some of my rocker arms are loose. I can jiggle them around by hand. The pushrods spin under the rocker arms with no resistance. I thought that you were supposed to tighten the rocker arms down until there is just a little resistance, then go 1.5 turns from there. If thats true, wouldn't the rocker arm be hard to turn?
Old Jul 25, 2008 | 05:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Are pushrods supposed to rotate?
Not necessarily. If you lash everything until the pushrods don't turn anymore, you've almost certainly got far too much preload.
Old Jul 25, 2008 | 05:10 PM
RazorN8's Avatar
Car: 1987 camaro
are rocker arms supposed to jiggle around?
Old Jul 25, 2008 | 05:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They can, yes.
Old Jul 25, 2008 | 08:38 PM
4RCEPWRD's Avatar
Car: 82Z28
Originally Posted by Apeiron
They can, yes.
+1
Here ya go, check out this how to it will tell you all you need to know about getting them right.
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
Old Jul 26, 2008 | 10:04 AM
RazorN8's Avatar
Car: 1987 camaro
thanks guys
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
KO1
16
Oct 15, 2015 05:00 PM
mfp189
Sep 27, 2015 09:25 AM
