no fuel!!! help would be nice
Old Jul 26, 2008 | 05:27 PM
jd5944's Avatar
Car: 85 Camaro Z/28
Transmission: built 700r, B&M shift kit
so my car completly runs out of fuel...ive put a new carb, new fuel pump checked all the lines, we thought about maybe the lobe on the cam bein worn down so i currently have an electric fuel pump and still having the same problem...it only runs out of fuel when its floored..you can back off to about half gas and it will run alright
Old Jul 26, 2008 | 06:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: no fuel!!! help would be nice
Have you checked the strainer sock on the pickup in the tank?
Old Jul 26, 2008 | 06:34 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
This is a good idea. I've also seen Fuel line pin holes that didn't leak, but caused the pump to suck air at high RPMs.
Frozer!!!
Jan 19, 2024 04:55 PM
bamaboy0323
Sep 3, 2015 06:07 AM
fasteddi
Sep 2, 2015 10:29 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
