Do casting numbers describe engine type
Old Jul 26, 2008 | 06:34 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
What I mean is, let's say you have a 305 block in a '83 Camaro. Can you tell by the casting number if it's an L69 vs LU5?
They both use the same desplacement block with the same compression ratio. The difference being one has a carburated intake and the other CFI.
Just curious.
Old Jul 26, 2008 | 06:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Do casting numbers describe engine type
No
Old Jul 27, 2008 | 11:10 AM
Axle/Gears: 3.08
Thanks. I didn't think so, but just wanted to be 100% sure.
Old Jul 27, 2008 | 01:32 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
The serial number stamped in the block might. I don't know if they were putting the last digits of the VIN on the block back then or not, but if they match the VIN on the car, the rest of the VIN on the car will tell you.
Old Jul 27, 2008 | 02:01 PM
vwdave's Avatar
You can also search the RPO number in the console.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
midias
Aug 22, 2015 01:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
