Problems with spark plug wiresq
Old Jul 26, 2008 | 11:29 PM
musclecarfan87's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305ci TBI
Transmission: 700R4 Auto w/ OD
Does anyone else have a problem with spark plug wires melting with stock exhaust manifolds? I bought the car about a month or two ago, and its already going on its second or third set of wires... Is there supposed to be wire holders that aren't there? Its a bone-stock 1992 Chevrolet Camaro RS, 305 Auto. I bought some Accel wire holders, but they don't help very much.... The problem is worse on the drivers side (when I got the car, one wire on the drivers side was completely melted in half).
Any help would be appreciated.
Old Jul 26, 2008 | 11:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Problems with spark plug wiresq
Are you running your wires over the manifolds, or under them?
Old Jul 27, 2008 | 12:52 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
When my 1992 RS was stock, never had any issues with spark plug wires melting in their stock location. You may want to try using a different set of wire loom, get some heat shield made for plug wires or a combination of both. I currently have my plugs above my slp headers. Have not burned 1 yet.
Old Jul 30, 2008 | 08:36 AM
Engine: 305ci TBI
Right now they are ran over the manifolds. Sorry it took so long to reply... We are currently in the process of moving, and are staying with my wife's family......
I was thinking of making some, but I wanted some other opinions before I did anything.
Old Jul 30, 2008 | 08:44 AM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
If I remember my old manifolds, shouldn't some of the wires run underneath???
Old Jul 30, 2008 | 12:12 PM
86z/92rs's Avatar
Yes, stock cars had some underneath the exh. manifold
Old Jul 30, 2008 | 01:12 PM
Engine: 305ci TBI
I plan to swap to a 350 with headers before too long, I'm just tired of my car running like crap bc the wires keep working their way to the manifold. A guy I work with has a 91 RS, and he said that his mechanic fixed his from doing it... I'm going to take a look at it tomorrow.....
Will the stock wire lengths run underneath the manifolds? They seem a little short.... Unless the auto parts store gave me the wrong wires.....
Old Jul 30, 2008 | 01:18 PM
Car: 89 Formula
Engine: 383 SBC/HSR
Do you still have your heat shields on the stock manifolds? Those definately help keep the wires from touching the pipes.
The stock wires are cut in lengths to run a certain way to each cylinder. You would need custom wires to run them any differently.
Old Jul 31, 2008 | 05:11 AM
Engine: 305ci TBI
No, there are no heat shields on there. When I bought the car, it ran like complete crap, and after the first week I found one of the wires on the drivers side had melted completely in half. It is also extremely hot in the engine bay while its running, like the air isn't moving through it. Do these cars normally run that hot?
Old Jul 31, 2008 | 06:28 AM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Just for a quick fix until you get the headers you can use zip-strips to tie them up. put one around all 4 wires to that side, and then another between each wire and around the first zip-srtip. It will help keep even spacing. Then just use a couple more to get the wires to stay in a safe spot.
Old Jul 31, 2008 | 06:52 AM
Car: 89 Formula
Engine: 383 SBC/HSR
Yep, I use zip ties on my wires. You can get creative with them and set them up to look and work just like a wire loom.
Old Jul 31, 2008 | 11:28 AM
kozman's Avatar
Car: 89 Trans Am
Engine: 5.0 TPI
Axle/Gears: 2.73 Posi
Try these from Ecklers.com, I used them for my 89 TPI. You should have two post on the drivers side on one on the passenger side. Look around the engine compartment and you should see them, kinda flat post that these things slid on to. I'm not sure about 92 TBI but I assume the wires should be routed the same.
Corvette Spark Plug Wire Retainer, 4-Wire, 1988-1991
This stock replacement spark plug wire retainer is manufactured by GM or by one of its authorized suppliers for use as a factory replacement part. You will find the fit, finish and function meets all GM specifications. Using stock replacement parts from Eckler's, such as this spark plug wire retainer, is a sound investment in the restoration or repair of your Corvette.
Item# 20131 In Stock
$5.99 ea.
Qty:
Old Jul 31, 2008 | 12:55 PM
ashley51071's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I had the same problem when I bought my Camaro even with wire looms...what brand of wires are you purchasing? Don't get the cheap ones for like $20, go the extra money and get the ones that are closer to $50-75. I believe I bought the Bosch from AutoZone and they were the first ones not to melt. They have a lifetime warranty on them also, so if they burn out...take them off and get new set for free...or buy a new set, change one at the time (smarter to not get them confused) and then take old ones back and get money back...they do it either way with their warranty system.
Old Aug 4, 2008 | 08:44 AM
Engine: 305ci TBI
Doc221978 and Heat Seeker, do either of you have pics of how you have yours tied up? Might be a cost-effective way to cure the problem until I do my engine swap.
kozman, I do have the posts for the holders, so I might have to look into that...
ashley51071, I'm using the $35 wires from AutoZone (I forget the name brand at the moment), but for my next set, I'm going with MSD or Accel wires.
Thank you all for your input.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Feb 28, 2016 03:33 PM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
