Check Engine Light on, MAP sensor hose attaching Location????
Old Jul 27, 2008 | 04:05 PM
Peebo's Avatar
I just bought a 1986 Firebird with a 305. I got the trouble codes out of the OBD 1 and they are #32 and #34. Both mention the MAP sensor and or the Pressure Differential sensor as a possible problem. It has a 4bbl carb. on it.
My real problem, that I need an answer to is this, the MAP sensor is not connected to any vac hose, I went to the parts hose and got a long piece of hose, but I can't find a place to plug it into the manifold?? also, theres a skinny, tube type hose thats appears to be coming up from the back of the motor routed under the distributor thats just laying on the manifold (possible tranny kick down?) any advice on where the MAP sensor attaches, or a VAC diagram lay out for this car would be very appreciated. If anyone can help, please send email to peebosauto@gmail.com, or just message me on here.
Many takes
Old Jul 27, 2008 | 09:15 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Check Engine Light on, MAP sensor hose attaching Location????
Not sure if it will help, but Autozone's site has vacuum diagrams for some cars.
Old Feb 3, 2011 | 01:14 PM
First_Formula's Avatar
Car: 1988 Formula Firebird (deceased)
Engine: l03 V8
Transmission: T-5 manual
I believe the map sensor hose comes directly under the air filter housing, follow the v.a.c motor vacuum tube (on your air cleaner duct) and the plug should be directly to the left.
9192camaro
16
Feb 3, 2019 12:21 AM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
squiggy2
Aug 9, 2015 09:30 PM
