maxed oil pressure
Old Jul 28, 2008 | 07:23 PM
jg2006's Avatar
Car: 1991 camaro rs
Engine: 3.1 v6
maxed oil pressure
my 1991 camaro has 196k on it and the oil pressure skyrockets after the car warms up. once warm the needle stays buried (well over 100 psi) as long as i'm driving (60 mph) or speeding up from a stop. when idling it goes back down to low 20's (gauge goes from 0-80) or when going about 40 it will max out and then drop back down to 40-60 psi. the check engine light doesn't come on, the rpm's are always normal, and the car runs fine. what do i need to do so i don't have to worry about my oil pressure? is it just my oil pressure sender or is my oil pressure really that high? am i risking blowing a seal or gasket?
Old Jul 28, 2008 | 07:46 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: maxed oil pressure
its probably the sender/gauge, mine does the same thing
Old Jul 29, 2008 | 07:34 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
sounds like you have a bad oil press. sensor . its not too bad to change . located above oil filter with elect. connector going to it . common problem with our cars .
Old Jul 29, 2008 | 08:25 AM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
Dont forget to use a decent amount of teflon tape (plumbers tape etc) around the sensor's threads. It's a common place for oil leaks to occur and this not only will destroy the sensor again, but it will fly back and destroy any rubber bushings and mounts the oil happens to find.
I just replaced mine due to it being stuck maxed out all the time, it leaked and was installed without any tape obviously. With the new sensor and no leaking, my sensor shows >60lbs on cold start to warming up, then it makes it's way to normal pressures. Though, even then it's not uncommon for it to spike to 60 or more.
Old Jul 30, 2008 | 02:37 PM
jg2006's Avatar
Car: 1991 camaro rs
Engine: 3.1 v6
thanks for the advice - i just replaced the sensor and took it for a spin. The pressure never went over 80 and stayed just above 60 while driving normally and and idled just under 40 like it did before. thanks again
Old Nov 14, 2008 | 12:54 AM
joshwilson3's Avatar
Anyone know what size wrench is needed to remove the sensor?
And if I remove the oil pressure sensor, will oil come pouring out?
Oh, and would the cheapo sensor from Advance Auto Parts work fine? Which one do I need "with light" or "with gauge"?
My oil pressure will read 15-30 on startup and drop once warmed up. Also, after I get off the interstate and come to a stop, it drops to zero.
Old Nov 14, 2008 | 12:59 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
i believe its 1/2 or 9/16 wrench, oil wont come pouring out but a few drops might come out, and yes, the cheap sensor is fine.
Old Nov 14, 2008 | 06:19 PM
jg2006's Avatar
Car: 1991 camaro rs
Engine: 3.1 v6
i didn't have a wrench that fit so i just used an oversized angle pliers and after a little struggle it came loose. a few drops of oil is all you'll get, just make sure you don't break the sensor off.
Old Nov 22, 2008 | 04:43 PM
Well, the cheap sensor isn't the right part. I don't know how you guys are getting the cheap sensor to work as it only has two terminals, where as you need the more expensive sensor with 3 terminals.
I was unplugging the connector and the damn clip broke off!! I'll just wrap it up with electrical tape. Though, that damn plug don't want to plug up. I'll have to fool with it tommorrow.
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
solocus
Sep 2, 2015 12:14 PM
CamaroGuy350
Aug 30, 2015 02:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
