Sudden Hesitation
Old Jul 29, 2008 | 08:26 PM
dark_daku89's Avatar
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
Sudden Hesitation
Hey Folks!
Okay, my car just recently started hesitating on light, and hard acceleration at any speed.. It started happening after I did the following things..
Replacing valve cover gasket ( Still leaking)
removing number 3 spark plug ( I did double check this today, spark plug is
tight and wire is on properly)
Increasing fuel pressure (originally it was at 5 psi, I bumped it up to 6 psi..)
Now tomorrow I will go ahead and fix my valve cover gasket leak, it is dripping oil all over my spark plug wires, would that cause something to make it hesitate
also, increasing the fuel pressure might have made my carburetor out of whack, I did turn it down back to 5 psi but it still doesn't run right.
What else should I do to find out the problem..
Old Jul 30, 2008 | 01:28 PM
bigzeke's Avatar
Re: Sudden Hesitation
install a fuel pressure regulator and back down to about 4 psi need more info what carb what timing lot of things will give you this problem changing a plug and vc gaskets aint gonna give you this headache can help you need more info-------------------------------------------------bigzeke35592bird
Old Jul 30, 2008 | 03:21 PM
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
i do have a mallory 4309 fuel pressure regulator (originally a tbi car) timing was never touched, it was running great, 17 initial 37 total..
see sig for setup,
i do think it has something to do with fuel pressure, i think the car might be running way too rich, because before it used to take a pump or 2 on the gas on a cold start up, now it barely takes one before it starts up.. I'm thinking the float in the carburetor, or a needle and pin is stuck, going to have to take a look at that..
thanks
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
