Turn left and smoke
Old Jul 30, 2008 | 04:02 AM
87_camaro_v6's Avatar
Car: 87 camaro v6
Engine: 173/ 2.8
Axle/Gears: ?
Turn left and smoke
Alright. I have an 87 v6 that if i make a hard left it smokes at the steering wheel and drivers side under the hood close to the firewall. Looked under the hood and everything looks fine. I noticed its only when i make u turns. Also i put a brand new altenator on and it already sounds like the old one which just locked up one day out of the blue. Need help.
Thanks in advance.
Old Jul 30, 2008 | 07:01 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Turn left and smoke
What color is the smoke? What does it smell like?
Old Aug 25, 2008 | 12:32 AM
Car: 87 camaro v6
Engine: 173/ 2.8
Axle/Gears: ?
white and cant describe the smell of it. its not burning oil and its not over heating.
Old Aug 25, 2008 | 04:12 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
If it kind of stings (or tingles) in your nose then it's PVC wire insulation.
You could have an unfused wire being pinched by the engine, steering gear, or wheel suspension. If so you could be facing an electrical fire and serious damage. I'd put a lot of effort to inspect everything closely and locate the culprit. Get under the car if you have to, but take care to support the car.
Old Aug 25, 2008 | 10:22 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
My first thought was coolant or some other fluid like windshield washer fluid or something spilling out on turns and landing on the exhaust.
Fronzizzle
Mar 18, 2019 08:29 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
bdads
Aug 24, 2015 06:01 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Fronzizzle
Aug 9, 2015 01:15 PM
