Injectors wire order????
Old Jul 30, 2008 | 10:17 AM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
im not sure if in the past my injectors plugs have been mixed up...how do i know the right order???
does anybody not the identification of injectors???
car:1989 t/a TPI...
i expect that because before 3000rmp some engine lack.
07-503-8xe cam... normal?its not so wild?
224 230dur @ .050
112lsa
503 510 lift
Old Jul 30, 2008 | 10:36 AM
snardos's Avatar
Car: 1992 camaro z28
Axle/Gears: 2.73:1
Re: Injectors wire order????
You can't mess up the order unless you are able to stretch the wire across to the other bank. All the injectors on the drivers side fire at the same time and All the injectors on the passenger side fire at the same time.
Old Jul 30, 2008 | 02:31 PM
FOX-GTA_89's Avatar
I learn something today....was sure each injector was shoting at each admission on each cylinder...
jklein337
Sep 19, 2018 06:23 PM
Jae992
Aug 27, 2015 09:07 AM
Brcharrelson
Aug 26, 2015 07:47 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
Bryan F
Aug 18, 2015 02:28 PM
