How can i get my car to start on the first try?
Old Jul 31, 2008 | 12:44 AM
kamero13's Avatar
To start off, i have an 86 z28. Anytime i start it, i have to pump the gas pedal a couple of times. and i have to do it like 3 times before it starts. All you hear is cranking, while i continuously press on the gas. What do i need to do to get it to start first try with just simply turning the key??
thank you.
Old Jul 31, 2008 | 01:18 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: How can i get my car to start on the first try?
Well, I have a similar problem. My car is a 86 IROC with a TPI 305. It usually starts on the 2nd or third try without the pedal being pushed. My problem used to be exactly like yours. I replaced the Idle Air Control valve and now no pedal is required. Are you getting any codes? If your car is TPI then when in "Cranking" mode you are not adding any more fuel when you are pumping the gas, Just more air. (the ecm suspends fuel, limiting it to just what it is programed to "Squirt") At least that is how it was explained to me. You could check your 'cold start valve'....
Old Jul 31, 2008 | 01:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Cold start injector, perhaps?
I believe we are talking about a TPI engine. Pumping the gas does nothing. It isn't like a carbureted car.
Old Jul 31, 2008 | 02:04 PM
kamero13's Avatar
yea, mine isnt a TPI its got a carb.
Old Jul 31, 2008 | 02:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Replace the fuel filter, make sure it still has the drainback "flap". This is a q-jet right?
Make sure the well plugs aren't leaking. One way to check, when the car hasn't been driven for a day or two, remove the air cleaner and work the throttle with your hand, do you see the dual squirts, or is it dry? If it's dry, then you need to plug up the well plugs - they are leaking.
That's the typical sign of an old unmaintained carb'ed car. My car, cammed an all, will fire up with the FLICK of the key. It's great!
For the guy with FI, geez! I've never heard of that happening on an FI car! Check the codes?
Old Jul 31, 2008 | 02:41 PM
Ford2transam's Avatar
Car: 1983 Trans Am ALL STOCK which is go
Engine: 305low
Axle/Gears: stock
It carbed/fuel injection? more importantly is it electric or manual fuel pump?
Matt
Old Jul 31, 2008 | 02:48 PM
Engine: 305low
Axle/Gears: stock
Which is why I asked I didn't know if it was a swap or stock or what :biggrin:
and yeah when those q-jets get.. older they can be a pain to start. I'm rebuilding one at the moment for my car.
Matt
Old Jul 31, 2008 | 04:13 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
hotter coil
move timing
check fuel preasure
change ign parts
choke set-up
Old Jul 31, 2008 | 05:32 PM
five7kid's Avatar
Assuming q-jet:
Also check for proper operation of the choke. When cold, the choke butterfly should snap closed when you open the throttle a little.
Old Jul 31, 2008 | 09:03 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Originally Posted by kamero13
[B]Anytime i start it, i have to pump the gas pedal a couple of times. and i have to do it like 3 times before it starts.
I would recommend pumping it like 4 or 5 times.
Old Jul 31, 2008 | 09:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
one pump is all you need when everything works right.
Old Jul 31, 2008 | 09:54 PM
jpeden31's Avatar
Car: 1984 z-28
Engine: 305H.O. L69
Axle/Gears: 3.73 G80 GT4
yeah, mine does that if i go a few days between starting it.i just rebuilt the carb and it will take 6 secs of crank to start but i dont have to pump it, could it be my well plugs?
a surefire fix
remove wiper fluid from reservoir and reroute hose to the primaries, fill with everclear, 1 sec of squirt should fix your problem
disclaimer: its fun when it backfires
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
