camaro dies out please heLP!!
Old Jul 31, 2008 | 09:40 PM
iroc3o5's Avatar
i have pasted in a video of my problem, and i sort of narrate it and explain the problem. in the vid i mention a coroded battery to starter cable, but i have replaced it and it doesn't help. ignore that. watch the end of the vid, of the car dying please.
http://vids.myspace.com/index.cfm?fu...deoID=39766078
when the car is in gear, and i tap the gas (goose) it, the car responds normally, and instead of going back to idle, it dies. shuts off completely.
reverse, drive, ect it happens, slow speeds, 25 mph, it will just die if i goose it.
right now i have the idle rpm turned up higher than usual, and it will almost die... then stay alive. but thats only a band aid. how do i fix this??
Old Jul 31, 2008 | 10:25 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Re: camaro dies out please heLP!!
I had a similar problem on my 86Z with the rochester 4 barrel. Something to do with the float at least that's what the mechanic said. May want to check the carb forum.
jklein337
Sep 19, 2018 06:23 PM
pimp2303
Jul 27, 2017 02:03 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
legendaryhero7
Aug 12, 2015 06:19 PM
