Harmonic Balancer... To get a new or just a seal
Old Aug 4, 2008 | 01:32 AM
mustangslayer86's Avatar
Car: '88 GTA / '93 Z28
Engine: L98(350) / LT1 (350)
Transmission: 700R4 / 4L60E
Well the title says it all. My harmonic balancer seal broke and I was wondering... Would I feel comfortable just replacing the seal or should I get a completely new balancer? Honestly, if the seal will last me a good while thats good too, but I just don't want to have to worry about it riding down the road. I'm wondering how durable they are. Can someone give me some suggestions or provide some good links? I'll take a look at all of them. Thanks.
Old Aug 4, 2008 | 02:56 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Harmonic Balancer... To get a new or just a seal
Pull the balancer and check it. If the snout on the balancer has a lip/ridge, you're screwed and you need a new one.
If not, then just grab a new seal.
PS - I love those wheels and white letter tires on that car. That's my style. (and unfortunately only my style on this forum...)
Old Aug 4, 2008 | 04:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, you just need a repair sleeve and a matching seal.
Old Aug 4, 2008 | 06:58 PM
I grabbed a seal for now. I can't afford the full balancer and it's still hanging on there in good shape. I caught it just as it broke off in my driveway and has only been started once for about 10 seconds after its done so hopefully I didn't ruin it
Old Aug 4, 2008 | 07:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What are you calling the "seal"? The only seal on the balancer is the front oil seal in the timing cover, and when it fails it leaks oil, not makes the balancer fall off.
Old Aug 4, 2008 | 07:06 PM
Well its a really tiny ring that goes on the front of the balancer. It has a spring wrapped around the inside. Hang on, I'll check the specific name.
Timing Cover Seal? Sound right?
Old Aug 4, 2008 | 07:17 PM
Alright, now the guy at autozone is telling me I'm going to need a new harmonic balancer. The rubber has separated from the metal. I'm thinking I wasn't descriptive enough.
Old Aug 4, 2008 | 07:22 PM
Z28 MeTaL HeAd's Avatar
Engine: Carb'd LT1 w/ a Cam :)
Axle/Gears: Moser 9" w/ 3.75 gears
Yup. I didnt know that rubber insulator was replaceable?
Anyways, you can always go to a scrap yard and grab one from another 305/350...or, grab a decent one from Summit.
I think you can pick up a decent SFI balancer from Summit for just over $100.
Old Aug 4, 2008 | 07:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's the front oil seal. It's not on the front of the balancer though.
The rubber that's between the outer ring of the balance and the inner hub? That's not a seal, it's the elastomer ring of the balancer that absorbs the vibration. If that's bad, you need a new balancer.
Which of those do you need? They're very different parts.
Old Aug 5, 2008 | 02:45 AM
Autozone has one for $50. Could I get away with that?
P.S. if you could find a link in your spare time, that'd be cool if I need to get one from Summit.
Old Aug 5, 2008 | 09:10 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
The autozone one is as good as any.
Old Aug 5, 2008 | 07:35 PM
My dad bought one for $35. I'll install it soon.
I need to know guys... Is this a common problem or am I running that engine too hard?
Old Jul 3, 2009 | 04:38 PM
joshwilson3's Avatar
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
