Head Questions
Old Aug 4, 2008 | 07:38 PM
Trumaster_77's Avatar
Head Questions
What is the difference between angle port and straight port heads, besides the angle of the port? I am putting together a 406 and need a set of heads that will work with a set of Hooker 2055 headers.
Old Aug 4, 2008 | 07:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Head Questions
It's angle plug and straight plug. Straight plug heads have the plugs entering the chamber perpendicular to the head in a plan view. Angle plug heads have the plugs entering at an angle. The actual angle can vary depending on whether you're talking about a stock L98 angle, or a particular aftermarket design, for example.
Old Aug 4, 2008 | 07:56 PM
Re: Head Questions
Thanks for the correction. Is there any andvantage one over the other? I was looking to get a set of aftermarket cast heads.
Old Aug 4, 2008 | 08:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Head Questions
Angle ports in theory make a miniscule amount more power, but there's no real difference. Clearance for your headers is a greater concern.
Old Aug 4, 2008 | 08:03 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: Head Questions
I'd say angle plug heads usually fit better as far as exhaust. I believe the original idea came from GM saying that the spark is better exposed being angled.
Old Aug 4, 2008 | 08:05 PM
Re: Head Questions
I am concerned now. I may have clearance issues regaurding what?
Old Aug 4, 2008 | 08:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Head Questions
If your headers aren't designed with the plug angle of your heads in mind, you might find the plugs and the header primaries trying to occupy the same space.
Old Aug 4, 2008 | 08:23 PM
Re: Head Questions
Thanks for the input, I appreciate it.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
