car surging
Old Aug 5, 2008 | 04:47 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
car surging
my car will work fine some days and other days it will hardly run at all. this has been happening for about 2 weeks. it will either surge and all of sudden die when i am just cruising it or when i get into boost it feels like it is missing. i have tried replacing the fuel filter as well as using fuel injector cleaner or fuel treatment cleaner still not helping. any ideas? would this be a bad injector(injectors are svo 42s and have about 5k on them)?
Old Aug 6, 2008 | 09:06 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: car surging
I would check both of these:
1) The fuel pressure at the rails - it could be the fuel pump is failing.
2) The distributor control module - these go out sometimes (about $30 at autozone)
I've had both of these fail on me and, when they do, the car barely runs or dies when running.
Hope this helps!
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
