Mass air relay?
Old Aug 5, 2008 | 08:23 PM
Jcous76's Avatar
Mass air relay?
Hi all, I have a 89 Formula 350 that just rolled 64,000 and to celbrate itself the check engine light had come on. I brought the car to a local garage and had him check the codes and he said it was the Mass air sensor but before I go and try and locate a replacment to try and find a relay. So id like to know if anyone has encountered this issue before and if so how it was corrected.Any info would help!
Old Aug 6, 2008 | 08:56 PM
Vader's Avatar
Re: Mass air relay?
Verify power to the MAF with the ignition on:
You can also test the MAF output signal with the engine running:
Old Aug 7, 2008 | 02:48 PM
Jcous76's Avatar
Re: Mass air relay?
The thing is when I initially start the car the check engine light does not come on. After driving the car about 150 feet or so then it comes on. When I started the car at the shop no codes came up so I took it around the block then left it runing once the light came on. Thats when the mass air code came up. I will buy another mass air if need be but would like to make sure that this is def the issue
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Thornburg
Aug 27, 2015 08:28 PM
