Charcoal canister smells strongly of gas...
Old Aug 6, 2008 | 01:36 PM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
I would expect it to smell of gas somewhat...since it does have the vapors running through it.
But I'm wondering if these things can get pretty "full", kind of like an air filter or something like that...
Or maybe the valves on top are clogged?
Any diagnostics I can do with this thing to make sure its doing it's 'job' ?
Old Aug 6, 2008 | 04:16 PM
discostu's Avatar
Re: Charcoal canister smells strongly of gas...
They can get flooded with fuel and then they don't work. Not sure what style of canister you have, but if there's a paper filter on the bottom of the canister, you can change out that filter. If you've got a sealed canister, I don't think there is any maintenance you can do.
Not entirely sure if this would work, but I think if you hook the control vacuum line up to manifold vacuum instead of ported vacuum, your car should run really rich at idle. I'm not sure if there's any vacuum break solenoids in the way that would stop it from working at idle, but you could watch it on your O2 sensor, the volts should go way up.
Old Aug 6, 2008 | 08:52 PM
Vader's Avatar
The '86 should have a compressed glass filter on its bottom:
And '86 should also have a solenoid for EVAP purge control:
Verify that both are intact, and that there is vacuum available at the purge line.
Old Aug 6, 2008 | 10:04 PM
Car: 86 Firebird
Engine: 2.8 V6
Yep, thats the one I've got...
I asked the people at AdvanceAuto if they sell those filters, got a no.
So basically I should just unplug those vaccuum lines at the solenoid end and see if there's a vaccuum to be felt?
If so, that's easy enough.
Old Aug 7, 2008 | 06:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I bought one, which I still have, at CarQuest a while back. If you need a part number let me know and I'll dig it out.
JamesC
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Racerx974
Sep 19, 2015 10:16 AM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
