Stud girdles and benefits
Old Aug 10, 2008 | 06:08 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
Is it worth using rocker arm stud girdles? I picked up a 383 LT1 that has 1.6 Harland Sharp rocker arms and I have professional products rocker arm stud girdles but I do not have the right nuts/bolts for it. What are the benefits for using the stud girdles and is it worth it to install? I'll need to figure out what nuts/bolts I need and I will need some tall valve covers. Also, how are these things installed? Anyone got photos?
Old Aug 10, 2008 | 06:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Stud girdles and benefits
I use a stud girdle because my valve springs have around 300# of seat pressure. When the valve is open, there's around 800# of pressure. The girdle keeps the rocker studs from deflecting under those extreme loads.
Having a stud girdle is about the only reason you need tall valve covers. Longer than stock valves is another reason. Roller rockers on stock length valves should fit under a stock height valve cover.
This is a BBC stud girdle. SBC valves are all on the same plane.
Old Aug 10, 2008 | 08:01 PM
Car: 1992 z28
I would need to get the correct poly lock nuts for use with stud girdles correct? What holds the stud girdles to the nuts? Thes one I have are two-piece with 4 allen screws to tighten the two pieces together and there are springs between each half of the stud girdle at the two center screws (make sense?)
It looks as if you tight the stud girdle to the wider (upper) shaft nuts but I do not see how they would be held on and prevented from moving up or down. Here are some pics of what I have...
Attached Thumbnails Stud girdles and benefits-cimg6680.jpg   Stud girdles and benefits-cimg6681.jpg
Old Aug 10, 2008 | 08:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
You need special poly lock nuts that the stud girdle fits over. You then just tighten the stud girdle over the nuts. Yours has allen screws. Mine uses 5/16" bolts. I'm not sure on the purpose of the springs. Probably just makes it easier to install by holding the 2 sections apart as you slide it over the rocker studs.
This is what you need. $8 each and you need 16 of them.
http://www.jegs.com/i/JEGS/555/20502/10002/-1
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
New2Chevy
Sep 28, 2015 12:35 AM
Billyadams
Sep 22, 2015 08:25 AM
355tpipickup
Sep 13, 2015 11:35 PM
