Pushrod getting stuck?
Old Aug 11, 2008 | 03:51 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I need a little help here, I'm converting a 350 from flat tappet to factory roller cam. I'm using a roller 350 block with world products s/r torquer heads w/ guideplates, factory roller lifters, production lt1 roller cam, and manley 7.15 length pushrods. Everything seems just fine except for one pushrod that seems to get stuck, it gets bound up when pushed down between the hole and the guideplate.. its not serious and will pop back up with a light tap.. how do I go about correcting this? Edit: Upon further inspection it appears that the pushrod simply will not go perfectly straight into the lifter, it isn't very noticeable with the lifter on the base circle of the lobe but at higher lift it becomes a problem.. it only effects the one..
Old Aug 11, 2008 | 04:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Pushrod getting stuck?
What rockers are you using?
Old Aug 11, 2008 | 07:11 PM
89RsPower!'s Avatar
Figured it out, didn't notice it at first but the guideplate was slightly crooked, straightened it out and all is well.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
tmellott89
Oct 14, 2015 02:06 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
