HELP FAST...Full length headers & starter???
Old Aug 12, 2008 | 05:26 PM
Cody Ashby's Avatar
Car: 1991 Firebird Formula
Engine: 6.0 LQ4
Transmission: TKO600
I have a 1991 Firebird formula which i have built a 383 stroker for..anyway.. i have a 168 tooth flexplate and hedman full length headers..I can not seem to find a starter that works..do i need the 153 tooth flexplate with those full length headers in order to get everything to line up and fit??
Old Aug 12, 2008 | 05:55 PM
danandamy's Avatar
Car: 86 Camaro
Re: HELP FAST...Full length headers & starter???
I know it probably doesn't help much but as far as the starter fitting to the block, on my 86 (305 but block size is the same) I'm running the stock Delco starter on it. Now, if I remember right, I had to leave the header unbolted after jimmying it into position and then install the starter before bolting the header up but it all fit, and I'm running full length hedmans as well.
Old Aug 12, 2008 | 06:15 PM
Cody Ashby's Avatar
Engine: 6.0 LQ4
is yours a 153 tooth or 168 flexplate though..?
Old Aug 13, 2008 | 02:41 PM
bigzeke's Avatar
im running a 168 tooth flywheel with the big stock bulky starter ,the trick is to leave that header loose completely until you tighten the starter then your gucci ---------------------big zeke 355 92 bird
gta892000
Aug 11, 2019 11:16 AM
sahlomonic
Sep 20, 2015 07:15 PM
corey8084
Sep 17, 2015 02:56 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
