best way to clean ground terminals???
Old Aug 12, 2008 | 06:49 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i think i may be having ground problems
to narrow it down i want to clean behind the cylinder head and where the negative cable bolts int front of the engine block
but clean it with what? i can see oil deposit on the engine block of 20yrs of use and the cylinder head is a pain to get to with so many wire harnesses in the way but i want to spray taht down with something and take a wire brush to it
any suggetions?
Old Aug 12, 2008 | 09:12 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: best way to clean ground terminals???
any suggetions?
Sandpaper works for me. I moved my ground connections from the back of the head to under the left rear fuel rail bolt. Much easier to get to.
Old Aug 12, 2008 | 10:26 PM
ChoobinatoR's Avatar
just what i was thinking.. some solvent and a wire brush and go to town.
you can d/c the wires too if they get in the way.. shouldn't be too hard to re-connect um, gl
Old Aug 12, 2008 | 10:36 PM
Travis odell's Avatar
Car: 89 chevy camaro rs
Engine: Tbi 305
Axle/Gears: 3:73s
Wd40 and sandpaper is what i use.
Jorlain
Oct 8, 2015 01:57 AM
billybob6110
Sep 23, 2015 01:30 PM
IROCtometal
Sep 9, 2015 10:01 AM
Gunsbee
Sep 7, 2015 07:10 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
