Overbore & CR Calculation Problem
Old Aug 13, 2008 | 11:39 AM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
I run a Jasper "355" and I am in the process of a head swap. I'm trying to calculate compression ratios, however I am getting 2 different bore & CID numbers from 2 different situations.
First, the fella at Jasper emailed me this:
"The block is bored 40 over and the crank is 10 under on both rods and mains. Stroke is 3.48". Using the corrective formula (bore x pi x stroke x 8) brings CID to 353.841. Since the normal dispacement increments is 5 per 30 thousandths, you would round the result up to 355"
When I do that out longhand, I get 353.35 (close enough). That also means I have a 4.040 cylinder bore. The calculator I am using to find CR tells me my CID is 356.88.
http://www.projectpontiac.com/ppsite...nt/view/16/30/
What am I missing here? Am I correct in my bore of 4.040 and stroke of 3.48? Please help me straighten this out so I can get accurate calculations.
Thanks...
Eric
Old Aug 13, 2008 | 01:01 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Overbore & CR Calculation Problem
355 is .030 over
357 is .040 over
With 3.48 stroke
Old Aug 13, 2008 | 02:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
This is why government-run lotteries are so successful - people haven't learned math in government-run schools.
The volume of a cylinder is the area of the base times the height. The area of the base is the radius squared times pi. The radius is one half of the diameter or bore. For a 4.040" bore, that's 2.02" squared times 3.14159. Stroke is the height, so times 3.48". Times 8 cylinders, 356.879 cubic inches, rounded to 357 cubic inches.
Old Aug 13, 2008 | 02:55 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
Gawd Bless It!! I'm glad I asked, a BOSS 357 sounds much cooler. Thanks for helping me out with that, the CR calculator makes much more sense now.
(although I do have to change my liscence plate now...)
Old Aug 13, 2008 | 03:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Call it what you want, it's still a 350.
Old Aug 13, 2008 | 03:09 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Send a PM to JT and see if he'll change your screen name here now
Old Aug 13, 2008 | 03:12 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
Ahh, ever the voice of reason. Your advice is usually spot on, but a sense of humor sometimes helps.
Good idea Sonix, I just did that. Hey, if they could use decimal points in screen names and plates, I'd be happy to be BOSS 356.879! I'm a Taurus, I gotta be precise!!
Old Aug 13, 2008 | 06:02 PM
five7kid's Avatar
For the purpose of CR calculation, it's a 356.879. . .
Admittedly, if you don't accurately enter details such as dome cc, head gasket cc, deck height, and chamber cc, it isn't going to be the determining factor, anyway.
Old Aug 13, 2008 | 08:06 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
I know 5-7. I had the rest of the information at hand, it's the simplest of things like say, the displacement, that gives me the hardest time. Jeez...
Old Aug 13, 2008 | 08:21 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
This is why I made a spreadsheet to calculate all this for me. Much faster and far less of a chance of me screwing it up.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
