few questions about 2 and 4 bolt main block
Old Aug 16, 2008 | 03:28 PM
cam92rs's Avatar
Car: 25th anniv. camaro
Engine: 305 tbi
ok, as of now, the camaro ive been working on threw a rod (pretty sweet lookin if you ask me, ill get some pics up of it.)my question is. will the crank and rods from a 4 bolt block work in a 2 bolt block. i keep hearing stuff about a large journal and small. is that the thickness (so to speak) of the bearing, well, the width i guess? im still in the process of tearing it down. its basically bare besides 1 piston and the balancer and the flexplate. if i can swap all the parts onto the 2 bolt main from the 4 bolt,that would be great. i would use the 4 bolt but it needs alot of work, the cylinders are out of round and im sure they have some pitting. the other (old) 2 bolt main has a crack in the water jacket, that was goin to be my next choice, but i dont have the crank to it anymore. ....
oh, and i guess a stock bottem end of a sbc 350 wont handle 5800 rpm.
Old Aug 16, 2008 | 04:02 PM
Guest
Guest
Posts: n/a
Re: few questions about 2 and 4 bolt main block
It doesnt have anything to do with 2 or 4 bolt, the small journal cranks are old cranks... pre 67 or something. I'm not sure the exact year.
Old Aug 18, 2008 | 03:19 PM
cam92rs's Avatar
Engine: 305 tbi
ok, so by the sounds of it its good news kinda. both blocks are between 78-84. but the block that threw a rod, everything is .010 over, the rods and the crank. so, i heard that the crank wont work, but maybe it will, ill get some more info and input on that. but is it goin to be worth getting the other 4 bolt crank turned for .010 or should i just go with the eagle rotating assembally like i was planning. also. when it is .010 does that make the bearings and crank weaker? stronger? or the same?
since i threw a rod, and messed the crank up on those journals. the main journals look clean. should i just rebuild the 2 bolt main, or work on the 4 bolt. they are both bare, both will get bored .030 over. but the 4 bolt will need align honed. the 2 bolt dont. im looking to get around 500 horse. spinning around 6,000 rpm. street strip. the cam is healthy, 565 lift straight across. solid lifter. torker 2 intake, and a 3000 stall is getting installed. everything will come in around 2400-2500. and end at about 6500-7000.
new plans i think, go .030 over on the cylinders, throw a stroker crank and eagle rods in her and be done.
do they make stroker cranks that dont have to have the block chamferred for the size?
Old Aug 18, 2008 | 04:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The crank will work fine, but it'll need to be turned down further if you've thrown a rod.
There's no such thing as a "4 bolt crank". Any crank can be used in a 2 bolt or 4 bolt block. For that matter, even the block castings are the same, the only difference between a 2 and 4 bolt block is in the machining.
There's no difference in strength.
It's up to you. I'd build whichever one needs less machining, which is the 2 bolt.
How much power you get out of it is going to depend on your heads, which you haven't mentioned at all. A .565 cam is probably going to have a higher powerband than you're looking for. The Toker II is a horrible, horrible intake, too.
No stroker cranks need to have the block chamfered for the size.
Old Aug 18, 2008 | 05:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
"block chamfered for the size"? I'm not sure what you mean there.
But I thought you need to clearance the oil pan rails with a stroker crank commonly.
Old Aug 20, 2008 | 06:19 PM
cam92rs's Avatar
Engine: 305 tbi
well, im workin on all the internals. now tryin to figure out what cam i have? i found this i think its a stock gm cam. i need help id'ing it. the only numbers i can find are MWM32 or 52. 36140 and the date, 11-05-98
evilstuie
Jan 9, 2020 08:29 PM
Reddeath210
Oct 6, 2015 08:20 AM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
