How about a real small solid cam for a DD?
Old Aug 21, 2008 | 12:34 AM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
I've been thinking real hard about replacing the 2.8 v6 in my DD with a warmed over 350. The 2.8 is absolutely gutless and gets terrible gas mileage for how slow it is(low 18's in the 1/4 mile).
I was thinking about using some moderately ported 416's I've got and something like an XS256. How often would I have to adjust the valves assuming I used proper hardware?
My reasoning for even thinking about a solid cam is that I believe it would return better economy, horsepower, AND low end torque than a similarly sized hydraulic cam.
FYI my 280z came from the factory with solid lifters.
Old Aug 21, 2008 | 11:31 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: How about a real small solid cam for a DD?
Every oil change or so.
How often do you lash the valves on your '77 280Z?
That's a microscopic cam. You can get away with the XS262 i'd think, since it's on a 350, and it'd still be tame.
Old Aug 21, 2008 | 12:33 PM
327???'s Avatar
That's doable, that works out to roughly twice a summer. Am I off base with my assumptions about a solid vs hydraulic?
My 280z hasn't run yet so i wouldn't know. It's a completely different design being an OHC engine. I'm still putting the engine together. I just thought it was an interesting tidbit to point out.
Old Aug 21, 2008 | 12:42 PM
Sonix's Avatar
Car: 1982 Trans-Am
Yea, that's pretty accurate about a solid cam. You get a wider powerband, so more low end and more top end. Not a life-changingly large difference though, so don't set your hopes too high.
Old Aug 21, 2008 | 12:56 PM
327???'s Avatar
Anything's better than the 2.8......
Old Aug 21, 2008 | 01:18 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
For a cam that size, there's no benefit to justify the expense of changing to a solid setup. You'd be best off with a hydraulic roller.
Only when you've pushed the duration of a hydraulic roller to the point where the duration, overlap, and engine rpm are adversely affecting low speed torque, driveability and valvetrain stability, does it make sense to go solid roller.
And if you're thinking solid flat tappet, again there is no benefit for the rpm range you're targeting.
Old Aug 21, 2008 | 01:41 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Yeah, unless you really like working on your car, it's not really worth the trouble unless you're revving outside the range of hyrdaulic lifters. I love excuses to work on my car, but not everyone has my sickness.
Old Aug 21, 2008 | 08:48 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
if you are looking for a cam anywhere that mild you wont see enough of a boost in power to make it worth the hassle of adjusting lash, especially if itis a DD. if you were shooting for 7000+ RPM, and it wasnt daily driven i could see going solid.
Old Aug 23, 2008 | 12:52 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
I think he's after fuel economy.
So, what do you guys think would be the best V8 combination to get the most miles per gallon?
That's a head-scratcher,huh.
Old Aug 23, 2008 | 02:49 PM
327???'s Avatar
That's what I'm trying for...
I bet a vortec headed engine that had the chambers and piston tops ceramic coated with a similar roller cam would do good.
Old Aug 23, 2008 | 04:33 PM
Engine: 350 4BBL
My best MPG setup would be:
305 with swirl port heads,
hyper pistons
"peanut" cam
full roller rockers to reduce friction
stock intake with TBI
fuel map in ECM with really lean cruise
195° thermostat
electric cooling fans that are off during cruise
Oh look, I just invented a '92 L03 with roller rockers...
Old Aug 23, 2008 | 05:20 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Wouldn't a decent exhaust from the headers back give a decent increase in power and mileage? By decent I mean noticeable, not some huge increase.
Old Aug 23, 2008 | 06:27 PM
impaled's Avatar
if you want something with good gas milage, a cammed, and built 350 is not the answer.
if you have the cash, maybe an LT1? they are pretty cheap and make decent power near stock and will most likely get better gas milage than the gen one SBC's.
another option would be to build a really mild 350. with your heads a really small cam and tune it perfectly and spray it. it wouldnt necessarily be a beast without the spray, but when you spray it, it would be respectable...
the one question nobody has asked or answered yet, is what are you going to do as far as a fuel system... carbed? TPI?
Old Aug 23, 2008 | 06:47 PM
Engine: 350 4BBL
I don't think it would make any difference in highway mileage at all. The engine is only making about 20-25 hp at cruise.
It would make a difference in power at WOT.
EFI would get better mileage than a carb because of closed loop. I think that a TBI would get better mileage than TPI because of better atomization and longer time to mix with air.
Going with a newer (Lxx, better) design would be best, but fudgeing.
It's kinda hard thinking mileage for a change instead of horsepower, huh?
Old Aug 23, 2008 | 09:46 PM
327???'s Avatar
I'm thinking I'll run it with a megasquirt 2(I've built a couple) and maybe a used HSR or TPI. I've already got a fresh flat tappet 350 with dished pistons in the basement. I'll probably get a set of shorty headers and a 3" single exhaust.
I've already got a fast car or 2, this one just has to be able to keep up with a minivan at WOT.
An LT1 is a gen 1 sbc with slightly better heads and reverse flow cooling.
It is tough thinking mileage instead of power.
Old Aug 24, 2008 | 03:12 AM
84Z28406's Avatar
Fair enough, I never really thought about it that way. I had just heard that it would breathe easier and hence be more efficient. I guess what they meant was more efficient at making power. I suppose then that dropping in a modern fuelie would be best.
Old Aug 25, 2008 | 09:24 AM
impaled's Avatar
i am with you on that one. i am all about power. i dont care what MPG my IROC gets, as long as i can get to the track on one tank... or maybe just one direction. haha.
my stang is the good gas milage. it gets a consistant 15 driven hard. although most wouldnt consider that good.
back to 327???'s posts.
if you can run and tune aftermarket fuel injection well, it would definitely be your best bet, it would't kill the power and would get better MPG's.
Old Aug 25, 2008 | 12:29 PM
327???'s Avatar
I'm pretty sure I can make it run 13's and get 20mpg around town Based on the 305 I setup/built for my uncle. It is an L03 with lightly ported 416 heads, ZZ4 cam, performer intake, 350 TBI with 454 injectors, and a megasquirt. Currently the TCC doesn't lock. It runs 14.5 and got 16mpg while tuning(lots of throttle) and making 5-6 passes at the strip. The part throttle AFR's are still a bit rich.
Old Aug 25, 2008 | 06:09 PM
impaled's Avatar
it is entirely possible, the rear end gearing and trans is going to have a significant affect on the highway milage.
Old Aug 26, 2008 | 07:12 PM
327???'s Avatar
T5 and the factory 3.42 open rear.
junkcltr
Aug 2, 2019 11:12 PM
Reborn756
Sep 4, 2015 03:42 AM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
