Will the serp setup from a V6 work on a V8?
Old Aug 21, 2008 | 05:26 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Will the serp setup from a V6 work on a V8? I don't think it will but I want to make sure.
Old Aug 21, 2008 | 05:48 PM
TPI El Camino's Avatar
Re: Will the serp setup from a V6 work on a V8?
Yes it will as long as the engine you want to put it on has the same hole locations in the heads and block as the donor engine. GM made several variences on the set up, I know that vans, trucks and cars are a little different from each other. The GM Performance Parts kit is real similiar to the set up on my 89 TPI motor, but must be a little different, maybe in pulley size because the kit uses a shorter belt or the belt in the kit is wrong. I tried to install it before a trip last weekend and it wouldn't fit. The kit is still in the box and will go on the 406 in my Nova.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
loud91rs
Oct 5, 2015 10:05 PM
Eric-86sc
Sep 28, 2015 11:37 AM
tattmann
Sep 27, 2015 05:20 PM
