1 cylinder not fireing correctly
Old Aug 22, 2008 | 03:00 AM
Deshi00's Avatar
... obviously 1 cylinder not fireing correctly... from what ive heard its thought to be the comp going bad... what is new is. plugs, all but 2 wires, fuel pump/filter. injectors are good, and all valves have compression.....
anyone else have any ideas what might be wrong?
Old Aug 22, 2008 | 04:28 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: 1 cylinder not fireing correctly
Bad plug
Bad wire
Cracked post on distributor cap
I'm having the same issue at the moment. I used a timing light to figure out that cylinder 2 has an occassional miss. I haven't figured out why yet.
Old Aug 22, 2008 | 06:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The computer has no idea which cylinder is firing at any given time, so it's not your problem.
Old Aug 23, 2008 | 01:46 AM
bigboy123's Avatar
i would start out with a bad plug. change them all. Theyre cheap, and its most likely your problem
Old Aug 23, 2008 | 03:02 AM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Originally Posted by Viprklr
Bad plug
Bad wire
Check these first. I was once running with only 5 cylinders because of these problems. All on different cylinders too.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
64goatman
Sep 9, 2015 01:09 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
