What for are these?
Old Aug 24, 2008 | 01:51 PM
vjs's Avatar
vjs
What for are these?
Hi,
Just a question about what is this thing doing? Must it be connected by vacuum hose to the back of TBI carb or? As I saw today on my friends Camaro 1992 it was connected, on mine Camaro 1991 (TBI 350) it was disconected and just bolt was screwed in pipe.
Thanks in advance for the help.
Old Aug 24, 2008 | 04:20 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: What for are these?
MAP sensor.
Old Aug 24, 2008 | 04:27 PM
vjs's Avatar
vjs
Must it be connected by vacuum hose to the TBI carb? And why it was disconnected in my Camaro? Thank You.
Old Aug 24, 2008 | 09:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by jv9999
MAP sensor.
I don't know about TPI and TBI cars, but on CC carb cars, that's the barometric pressure sensor. If EFI is the same as CC carb, it shouldn't have anything but a wiring harness connector hooked up to it.
But, I've never had an EFI 3rd gen, so I couldn't tell you for sure.
Old Aug 24, 2008 | 09:35 PM
jv9999's Avatar
Engine: 5.7L/350
Maybe you're right, but why would a baro sensor have a vacuum line?
Old Aug 24, 2008 | 09:41 PM
five7kid's Avatar
Because somebody saw what looked like a vacuum hose nipple on the bottom of it, and assumed it needed a vacuum hose connected to it.
Happens a lot on the Carburetor forum.
But, I'm not sure about EFI.
Old Aug 25, 2008 | 02:14 AM
vjs's Avatar
vjs
I faund some info. It looks like MAP sensor, like in this listing http://cgi.ebay.com/ebaymotors/NEW-M...spagenameZWD1V
So the question is what does this little thing do? And must it be connected to TBI carb by vacuum line or let it leave disconnected like it is now in my Camaro?
Thank You.
Old Aug 25, 2008 | 09:53 AM
Stephen's Avatar
Car: 87 GTA
MAP sensor.
http://www.autozone.com/R,1608610/ve...ductDetail.htm
Old Aug 25, 2008 | 01:19 PM
five7kid's Avatar
I understand there's a MAP sensor somewhere on the car. Is there another sensor like that over in the in the driver's side rear corner of the engine compartment? That's where the MAP sensor is on CC carb cars.
Again, I don't know for a fact it's the BPS, because I don't have any EFI cars. But, it's mighty suspicious to me that it's in exactly the same mounting location as the BPS on CC carb cars.
As for what it does, it's input to the computer for vital operating operation. Whether it's the BPS or MAP.
Old Oct 31, 2008 | 03:43 PM
vjs's Avatar
vjs
I found what it is and what for the MAP sensor is. Here is the info:
The MAP sensor checks for variations in intake-manifold pressure. When everything is functioning normally, vacuum varies depending on engine speed and load. The MAP sensor relays this manifold-vacuum information to the engine's computer, which then regulates fuel and spark accordingly.
So I found it disconnected on my car. Should I leave disconnected it or should I connect it back? My car is chiptuned, so maybe the MAP sensor is not needed anymore?
Old Oct 31, 2008 | 04:05 PM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
I don't know how things are programmed on your car. Usually you would leave the MAP sensor connected. It shouldn't hurt to connect it back up and see how she runs. It may run better. In the picture it looks as though it is connected. Also, was that AC removed from your car too? I can see your heater core!
Old Oct 31, 2008 | 04:15 PM
vjs's Avatar
vjs
It was just vacuum line disconnected from TBI carb to MAP sensor when I get the car.
Yes, I have removed AC and installed non AC heater box.
Old Oct 31, 2008 | 04:27 PM
OldCelica's Avatar
Hook it up. See what happens. I believe with it disconnected you should be running rich. I could be wrong though.
Old Oct 31, 2008 | 04:37 PM
vjs's Avatar
vjs
I will try to drive with connected and disconnected. Let see if I'll notice the difference.
Old Oct 31, 2008 | 07:02 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
the tpi cars didnt have a map sensor they used a MAF sensor the 91-92 years used the map sensor since they went to speed density the TBI cars used MAP sensors i think though
Old Nov 1, 2008 | 09:56 AM
Silver87's Avatar
Car: 87 T/A
Engine: 305 4BBL
Transmission: 700R
On my carbed 87, the passenger side is the Baro sensor and does not have a vacuum line. The one on the driver side is the MAP sensor and is connected with a vacuum line. Take that bolt out of the nipple of the sensor because it can't sense atmospheric pressure with it in.
