Ignition cylinder problem maybe
Old Aug 24, 2008 | 02:39 PM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
i can turn my Ignition switch Cylinder with out a key in it but it is not moving the rod that goes to the switch. Do i have a bad Ignition Cylinder or did something get disconnected.
Old Aug 25, 2008 | 04:08 AM
z28z34man's Avatar
Re: Ignition cylinder problem maybe
ttt
Old Aug 25, 2008 | 05:24 PM
z28z34man's Avatar
Before this happened the key turned kind of hard and then it didn't want to release the key if that help at all.
Old Aug 29, 2008 | 07:16 PM
z28z34man's Avatar
it wasn't the cylinder any ideas
Old Aug 30, 2008 | 01:50 PM
z28z34man's Avatar
the spring in the pic broke just in case some else has this problem
Old Aug 30, 2008 | 07:40 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i ended up swapping entire steering column for the same problem . fortunately i had one in hand . old column also had " loose tooth " syndrome so swapping them was a no brainer . still good to know there is a repair . thanks .
Old Aug 31, 2008 | 06:01 PM
z28z34man's Avatar
Not a problem that is what this board is here for the spreed of info.
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
