Engine combatibility late 90s 350
Old Aug 30, 2008 | 06:57 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
Would a late 90s (1999) 350 out of a chevy truck be combatable with Gen 1 heads and stuff? The seller says everything is the same. No casting numbers. I just wanted to make sure before I picked it up. When looking through parts books, most gen 1 heads are dated up to 95. Then again, vortecs heads were late 90s.
Old Aug 30, 2008 | 07:02 PM
rosco88ta's Avatar
Car: 88 Trans Am
Engine: 355 c.i.
Transmission: 5 spd.
Axle/Gears: 3:42s
Re: Engine combatibility late 90s 350
Yes your gen 1 heads will work, but you will have to use your gen 1 intake also.
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
My apologies, this seems to answer my question.
https://www.thirdgen.org/forums/tpi/...light=1999+350
Yeah, that's what I intend to do. Thanks.
Old Aug 31, 2008 | 12:55 PM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
What about cams, lifters and timing chains?
Old Aug 31, 2008 | 01:54 PM
rosco88ta's Avatar
Car: 88 Trans Am
Engine: 355 c.i.
Axle/Gears: 3:42s
I guess it depends on whether it's a vortec motor or not. I believe if it is a vortec motor it will have hyd.roller cam and lifters. I think you can replace them with a hyd. flat tappet cam but not real sure. I'll step aside and let someone else confirm that. Vortec heads are a good head but in stock form you are limited on your valve lift to .470-.480 something like that.
Old Aug 31, 2008 | 02:25 PM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
It's just a shortblock. No heads, cam or anything included. It does include the spider stuff for the roller lifters. I am wanting to buy it, throw RHS Vortecs, performer rpm, holley 750 and a comp xtreme 274 (I think) roller version in and go.
I was just a little unsure if the the cams were different or something. Summit lists most of the cams going from 87-95.
Old Aug 31, 2008 | 02:36 PM
rosco88ta's Avatar
Car: 88 Trans Am
Engine: 355 c.i.
Axle/Gears: 3:42s
How many miles on the shortblock? Are you going to go through the shortblock to freshen it up? Sounds like your on the right track. But I would get the block casting #, and find out what pistons you have in it for your compression ratio and such.
Old Aug 31, 2008 | 06:05 PM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
He says it has 66k on it. I was going to clean it up.
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
