tire on my new rim?
Old Aug 27, 2008 | 10:47 PM
kwp289's Avatar
Car: 87 Trans Am
Engine: V8 305 TPI
tire on my new rim?
I am buying some new gta rims, and I asked a mechanic how to take the tire off my current rims and put them on the new ones. he said I would need to go to a mechanic for a special machine. is this true? can I not do it myself?
Old Aug 27, 2008 | 11:32 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: tire on my new rim?
With the work it involves to do it by hand, it is well worth the $20 a tire to have them changed..... then you get them balanced at the same time, which will help out a lot.
Old Aug 28, 2008 | 12:09 AM
Stephen's Avatar
Car: 87 GTA
You wanna spend a few bucks or all week? Even if you manage to do it yourself, you still hafta take them in to be balanced.
And you hafta hope you don't scratch up the rim itself.
Old Aug 28, 2008 | 08:04 AM
MD83Z's Avatar
In the old says we used a car jack (small version of the off-road jeep style) ,with the square base on the edge of the tire,near the rim,and jack down using the car bumper. This breaks the tire loose from the rim. (car bumpers were higher then) Flip tire over and break loose the other side......Then use coated tire irons ( to protect the soft aluminum rim ) working one inner tire edge into the center of the rim ,and the other side off the rim......way too much hassle....
Old Aug 28, 2008 | 12:22 PM
kwp289's Avatar
Car: 87 Trans Am
Engine: V8 305 TPI
thanks guys...im going to firestone, its going to cost me $123.00
Old Aug 28, 2008 | 12:53 PM
MD83Z's Avatar
$123 to take 4 tires off and mount them on 4 new aluminum rims.....high speed spin ballance.....hmmm. maybe special glue on wheel weights?
Old Aug 28, 2008 | 01:02 PM
kwp289's Avatar
Car: 87 Trans Am
Engine: V8 305 TPI
what do you mean? is that a bad price?
Old Aug 28, 2008 | 01:11 PM
MD83Z's Avatar
well I figured it could run up to $20 each ....but I'm old and everything costs more these days....guess $30 each tire is OK
Old Aug 28, 2008 | 02:35 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
wait... $123 just to remove, re-mount, and balance 4 tires!? The local tire shop up the road from me charges me $18 to remove my back slicks and mount new ones.
Old Aug 28, 2008 | 03:25 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
A lot of the chain places REAM you on mounting and balancing now. They charge $15 to mount and $15 to balance, each. I luckily have access to a shop that lets me use their mounting and balancing machines myself, after hours.
But yeah, you can't do it yourself. Even with coated tire irons, on nice wheels, you will scratch them. The good tire mounting machines now (the euro type ones) do not contact the wheel at all during mounting and dismounting.
Hotrodboba400
Dec 10, 2019 07:07 PM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
fasteddi
Sep 10, 2015 09:32 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
