305 to 350 TBI with the 305 heads
Old Aug 31, 2008 | 07:31 PM
jamienoel's Avatar
Car: Mystifying 1989 TBI Camaro.
Engine: 1992 350 Truck Engine. TBI
Transmission: 700R4 when it wants to be.
I have an 89 Camaro. The 305 has been swapped with a 350 truck engine, but it's using the same 305 heads.
I've heard others talk about changing the injectors if you go from 305 to 350.
What are the specific TBI injectors I would need? Does the throttle body or intake need changed?
The engine was swapped some time ago and it seems to run fine, but it does set a code saying there is a lean condition at the oxygen sensor.
Thanks!
Old Oct 22, 2008 | 08:09 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
Re: 305 to 350 TBI with the 305 heads
Just go to autozone and get stock 350 injectors. The TB and pod is the same. 305 and 350 TBI intakes are the same. You should probably change the ecm or prom (check the sticky post), the ESC module and knock sensor.
also, how does it run with the 305 heads? thinking of using mine instead of the 359 truck heads
Old Oct 22, 2008 | 09:50 PM
jamienoel's Avatar
It actually runs quite well. When you step on the gas, it jumps; I have a hard time controlling that. The engine came out of a 90 pickup truck, so I imagine it has a lot on the lower end, which is probably why it jumps and takes off pretty quick. The old engine was smoking and I was told before acquiring the car that the engine was a 350 that had been taken from a truck, so I bought an engine rebuild kit for an 89 350 VIN K months ahead of time before the actual rebuild date and when I pulled it, I found the 5.0L stamp on the block. I was ticked off and didn't want to replace any of the kit (way past the date to return), so I went looking for a 350 engine with a one piece rear seal. Found one at a truck junkyard that someone overheated. Both heads were cracked, but the block was still good and the owner let me have it for $50.
There is a knocking though. After it is warmed up, it has a terrible knock that you can actually feel if you are touching the engine, but it's been running like that since 2002, which is when it was rebuilt. Knocks the worst when you LET UP on the gas. Someone told me it could be a wrist pin from the overheating? The rod bearings are all new and everything was tight, so I don't know. I've had the RPM's up pretty high a few times and it never blew.
I didn't know you would need to change the ESC, but it already has a 350 knock sensor.
I want to tear it down again and perhaps replace the pistons and rods.
The 305 did come out of a truck, but they didn't know it was a 305. They should have bothered to look.
Besides the heads, the intake and exhaust manifolds are from the 305.
Old Oct 22, 2008 | 10:19 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
maybe the knocking is detonation from a lean condition due to the injectors being too small? could even be the spark control (ESC) screwing something up too. I heard the ESC was different so I double checked and the part #'s are different.
Old Oct 22, 2008 | 11:15 PM
jamienoel's Avatar
I'm not sure why it would knock worse when you let off on the gas though. It also doesn't knock as much when you put it in gear.
It's been doing this for 6 years. I imagine if it was a bearing, it would have blown by now?
Only does it after it is warmed up.
I'll check into the ESC and see if I can get a cheap used one. I wonder if you could just take a truck computer and use it or if the wiring would be different? Would be something to check into.
I just want a good running car that doesn't throw codes.
Old Oct 23, 2008 | 04:36 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
pretty sure the 350 truck ecm works, I've been shopping around and I see a ton of them on ebay for like 45 bucks.
Old Oct 25, 2008 | 10:38 PM
jamienoel's Avatar
I have another computer from a Caprice of about the same year. I was told it was from an 89, but I see no difference in performance and it still throws the code for lean condition. I am going to see if I can find used injectors somewhere because I don't have the money right now for new ones.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
