proper oil pan removal procedure?
Old Aug 31, 2008 | 08:19 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
i have to replace my oil pan cause the chrome one likes to leak everywhere. my last attempt to remove my pan i had to use a engine hoist, and i had to lift the engine so high it was about to hit the firewall just to get pan to clear. is that normal or am i doin something wrong?
Old Aug 31, 2008 | 08:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: proper oil pan removal procedure?
You need to lift the engine no matter how you do it, but you can turn the crank so the counterweights aren't in the way and you don't have to lift it so high.
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
