92 camaro with 408 help
Old Sep 1, 2008 | 10:26 AM
arobunson's Avatar
92 camaro rs with sb 408 want turn pass 6,000 rpm something is killing my ignition i have a msd 6al and distribution durg herburt HER8551 car surpose to turn 7,000 rpm
Old Sep 1, 2008 | 10:56 AM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: 92 camaro with 408 help
Are you sure it's the ignition. The cam, carb and intake have to flow enough too. I have just an accell distributor, and I have been to 6,500 a couple times. Everything has to work together. What is the rest of the combo?
Old Sep 1, 2008 | 11:01 AM
arobunson's Avatar
vitor jr intake, 567 doug herbert solid cam 603 with 1.6 rockers, holley hp 850 dp cab.
Old Sep 1, 2008 | 12:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Heads are the important part there....
killing your ignition, as in it stalls out after?
Old Sep 1, 2008 | 04:20 PM
arobunson's Avatar
when the car rpm get to 6,000 fill like it quit firing, then pop real loud like it just started firing again because of the gas in the cylinder
Old Sep 17, 2009 | 12:37 PM
hereinmissoula's Avatar
lol... check the white pill plugged into your msd 6al... fifty bucks it says 6000... it's the rev limiter... change to what ever fits your needs
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
